Viewsonic n4060w dead... x3!
Goto page 1, 2  Next
PDMeat
PostPosted: Thu Jun 26, 2008 6:19 pm    Post subject: Viewsonic n4060w dead... x3! Reply with quote
I've got a total of 4 viewsonic n4060w LCD TVs in a quad wall setup. 3 died in 3 weeks, 2 within 2 days of each other! The symptom is I push the power button and the power LED flashes for a half sec and goes out.
After trying all the basics like new cables, different power source, different video source, letting the TV sit unplugged for hours, nothing works- it seems to have fried something the power circuitry or supply inside the TV.
Anyone have an idea? I'm not an EE but I know a few things and can take this sucker apart and provide more info (DVOM results) for a problem diagnosis.
Thanks in advance for any advice!
Pete
PostPosted: Thu Jun 26, 2008 9:32 pm    Post subject: Reply with quote
Check CS22 and CS21 (1500mfd at 16volts) in the power supply to see if the tops are mushroomed up.
PDMeat
PostPosted: Fri Jun 27, 2008 1:22 pm    Post subject: Viewsonic n4060w dead- bad PS leaking caps Reply with quote
CS19, 20, 21, 22, and 28 are all bulged and most are leaking slightly. I've seen worse on PCs but they definitely have issues.
PostPosted: Fri Jun 27, 2008 6:52 pm    Post subject: Reply with quote
Get R done! Change them and you should be fine.
PDMeat
PostPosted: Mon Jun 30, 2008 1:14 pm    Post subject: Viewsonic n4060w dead... x3! Reply with quote
Schweeeet. thanks for your help minnie!
Also, I found 1 power supply online (its like finding Elvis still alive) and I also came across a place that repairs power supplies.
I'll post back when I try the new PS and also if I send out and get the other two repaired and how they work.
FWIW there seems to be a lot of dead power supplies for viewsonic LCD TVs. Even on this site there was talk about the n3250. I have the same FSP power supply that those with the busted 3250s spoke of and had similar problems.
I called FSP and they are trying to locate some PS for me but they apparently don't keep any. Viewsonic won't even sell me one unless I have a warranty. I guess that says something about how well their PS are holding up. I smell a class action suit brewing...
Stan
PostPosted: Fri Jul 24, 2009 3:49 am    Post subject: Thanks for the help Reply with quote
Don't know if minnie is still around and will read this. I found this thread when my viewsonic N4060W died and I fixed it for under $10.00. Thanks for the info.
PostPosted: Mon Jul 27, 2009 10:09 pm    Post subject: Reply with quote
Very Happy
Steviee
PostPosted: Mon Oct 19, 2009 8:27 pm    Post subject: Re: Thanks for the help Reply with quote
do you mind sharing how? I am having the same issue with my n4060w. it doesnt power on till i hold down the remote for a min or two. Minnie - do you happen to know the part number for the power supply. Thanks in advance guys. Misery does love company Smile
[quote="Stan"]Don't know if minnie is still around and will read this. I found this thread when my viewsonic N4060W died and I fixed it for under $10.00. Thanks for the info.[/quote]
PostPosted: Mon Oct 19, 2009 11:47 pm    Post subject: Re: Viewsonic n4060w dead- bad PS leaking caps Reply with quote
This is what he replaced to fix it.
jayseeyes
PostPosted: Thu Jan 28, 2010 6:23 pm    Post subject: viewsonic N4060W 'Power-On' woes Reply with quote
I have a N4060W that took 20-50 times of 'turning-on' the power for switching the TV on. Thanks to suggestions in this thread, I fixed it easily.
Had the capacitors CS22 and CS21 (1500uF / 16V) replaced and the TV is back to normal again! Thanks Minnie (and all)!
Goto page 1, 2  Next
Page 1 of 2
