madman666333 Guest
Posted: Thu Aug 28, 2008 10:13 pm Post subject: convergance |
| i am trying to fix a 53fdx01b. i have the new ic`s but am not sure which resistors to check. can somebody help me so i dont have to check them all? |
Posted: Fri Aug 29, 2008 3:04 am Post subject: Re: convergance |
| madman666333 wrote: |
Resistor Location Value Part #
RK42 2.2 Ω 1 W AT03197S
RK46 1.5 Ω 1 W AT03193S
RK50 2.2 Ω 1 W AT03197S
RK54 1.5 Ω 1 W AT03193S
RK58 3.3 Ω 1 W AT03202S
RK62 1.8 Ω 1 W AT03195S
IK04 & IK05 STK394-160E CZ01341 |
madman666333 Guest
Posted: Fri Aug 29, 2008 9:18 pm Post subject: convergance |
| thank you but where are the stk394-160E you mention? sorry im new to all of this. im just an automobile mechanic trying to fix a tv. |
Posted: Fri Aug 29, 2008 10:14 pm Post subject: |
| STK394-160E replace STK392-110's STK392-150's and STK392-180's. |
madman666333 Guest
Posted: Sat Aug 30, 2008 7:23 pm Post subject: rk50 resistor |
| the resistor keeps blowing right away. i even replaced it with a 2 watt 2.2 ohm and still blew it! im not sure what to do next. thanks for your help. |
Posted: Sat Aug 30, 2008 7:41 pm Post subject: |
| Did you replace the 2 IC's? |
madman666333 Guest
Posted: Sun Aug 31, 2008 2:20 am Post subject: resistor |
| yes i did. the tv came with this problem. we acquired it from a friend. after i replaced the ic`s i noticed the resistor looked burned, and it happened to be one you told me to check. i replaced it and it worked for a couple of seconds then i smelled a burnning smell and qickly turned it off only to find the resistor had blown. so i replaced it again and the same thing happend again. so i know the new ic`s worked but the resistor keeps blowing and im not sure if the ic`s are damaged now. i just thought it would be a simple fix after researching it online but now its getting to be a project. now im determined to try and fix it as long as the cost is minimal. thanks again for your help and time. |
madman666333 Guest
Posted: Thu Sep 04, 2008 11:16 pm Post subject: rk50 fixed |
| i found out that i had purchased crappy quality ic`s from bluestaronline. i went to acme and got oem replacments for alot more but they worked the first time. lesson learned dont save a few bucks on electronic components get good quality parts. spend the extra few dollars and save your brain. now my free tv cost me roughly 100 dollars, still not bad for a 53 inch hitachi! |
Posted: Thu Sep 04, 2008 11:24 pm Post subject: Re: rk50 fixed |
http://forum.eserviceinfo.com/viewtopic.php?t=25932 |
madman666333 Guest
Posted: Fri Sep 05, 2008 7:46 pm Post subject: ic`s |
| thank you again for all of your help. if i lived near you i would buy you a drink. |
