joetiz1 Guest
Posted: Fri Aug 29, 2008 5:38 pm Post subject: Mitsubishi VS-45609 |
| The problen started off with convergence problems then the TV would turn on for a second(just sound) then shut down.withe the timer light on steady.. Now the timer lght stays on and the TV does nothing when power button is pressed .I tryed unplugging and waiting 10min and plugging back in no help ,any suggestions. |
Posted: Fri Aug 29, 2008 6:14 pm Post subject: |
| Replace the convergence IC's. |
joetiz1 Guest
Posted: Sun Aug 31, 2008 8:33 pm Post subject: mitsubishi vs-45609 |
I already have the manuals ..I will try the convergence IC's
hope this works .... I will keep you posted
Thanks Minnie |
Posted: Mon Sep 01, 2008 8:30 pm Post subject: Re: mitsubishi vs-45609 |
| joetiz1 wrote: |
Thanks Minnie |
If you have the service manual don't forget to check the + and - 28vdc pico fuses that feed the IC's. |
joetiz1 Guest
Posted: Tue Sep 02, 2008 2:28 pm Post subject: mitsubishi vs-45609 |
I have the board out right now and waiting for the ic chip
all the fuses checked good the only question I have is your saying the
convergence IC's but this set seems to only have one stk393-110 |
Posted: Tue Sep 02, 2008 9:44 pm Post subject: |
Recheck the pico fuses. STK393-110 is a 6 channel amp. So yes, there would only be one in this set. Usually when you unsolder the IC half of the pins fall out of the IC.  |
joetiz1 Guest
Posted: Wed Sep 03, 2008 9:57 pm Post subject: mtsubishi vs-45609 |
Minnie
I have been looking for the pico fuse but I can't find them I found resistors,I found the chasis grdI also found a fuse that states its A heater im thinking it may be a thermistor I still have not been able to try and see if the voltage is present to feed the IC chip i was waiting to get the new IC before I put the board back.would you know a coponent number for the fuses  |
Posted: Wed Sep 03, 2008 10:15 pm Post subject: |
| Looks like it's 24 volts. R8C60 .47 ohm 2 watt protects the -24 and R8C59 is the same rating and protects the +24. Look closely at the signal board for fluid leakage also. Look good everywhere. |
joetiz1 Guest
Posted: Sat Sep 06, 2008 4:40 am Post subject: mitsubishi vs-45609 |
I installed the convergence IC and made sure the resistors where good
when I went to turn on the TV nothing happened I could not find any leakage of antkind on the signal board or any other boards.
I will have to start tracing back power to see which component might be at fault....I dont even have the led light on the front either ..hope I can find the solution |
