MorphUnreal Guest
Posted: Sat Mar 12, 2005 7:09 am Post subject: Dell D1626HT Sony trinitron monitor.. needs fix please help |
okay. im a micro-electronic engineer student in australia and i'm trying to fix my friends monitor. The fault is the monitor 'stability control' is f__ked, the image is constantily disturbed by static and sits in the centre of the screen with about 2" border of nothingness around it, adjusting using the OSD does nothing to the picture.
after downloading the service manual off this site it said:
"Two common problems with this monitor are deflection faults resulting from failure of CXA2043Q, and video (colour) faults resulting from failure of FA4111 (colour will disappear after warmup - confirm IC is bad by using freeze spray ). Replacing the CXA2043Q requires above average soldering skills to not damage the main PCB during replacement."
as there is no image colour faults, i would assume CXA2043Q, but it doesn't outline the job of this circuit.
basically, is this the right part? is it worth doing? what parts and suppliers should i look at for replacement components? is it worth having a proffesional do this or just buy a new monitor?
any guidance would be greatly appreciated |
MorphUnreal Guest
Posted: Wed Mar 16, 2005 4:32 am Post subject: |
So I guess not?... |
Dean Guest
Posted: Thu Jun 23, 2005 3:36 pm Post subject: Dell Ultrascan 1600 moniter |
I also have the same problem , how did you go with it ? regards Dean |
Andrewj Guest
Posted: Mon Nov 03, 2008 5:06 am Post subject: Dell D1626HT Monitor |
This monitor is exhibiting a ripple edged trapizod deflection issue. About 40% compressed at the bottom and 10% at the top. I was wondering if anyone has replaced the CXA2043Q IC and if so exactly what problems it corrected and how difficult it was to replace. Is this a ball grid array mounted IC ? Any experiences shared would be appreciated. Thanks, Andrew. |
WRATH Guest
Posted: Mon Nov 03, 2008 5:17 am Post subject: |
By GOD, post a picture! |
3nstrans NOKIA • 15 rl 312 philetta Philips • 2sc2275 2sc2275a Inchange Semiconductor • A8.0E philips • OLED TV Repair Guide 2013 (55EA9800 Ch E • Panel CHIMEI INNOLUX N156BGE-L21 3 [DS] • Vizio VL470M LGD LC470WUH-SBR1-7R1 (T47U • s power panasonic • 2sa2142 Toshiba • IC-W32 serv Icom •
