sony 3400 v2
Ramji
PostPosted: Tue Jan 27, 2009 4:58 am    Post subject: sony 3400 v2 Reply with quote
i got a sony 3400 v2.chasis is SCC-C29E-A.The picture is wavy.I found one of the filter capacitor C619(850mfd/250v) is getting too much heat and causing problem and one of the resistor 330k has gone high value.Replaced both the filter capacitor in the powersupplu and the resistor.Now when i power on the tv is trying to start and the buse gets blown.The capacitor c619 is getting too much heat.What might be causing the capacitor too get too much heat.Need Solution.
With Regards,
Ramji
PostPosted: Tue Jan 27, 2009 8:42 am    Post subject: Reply with quote
1) Installed Backwards.
PostPosted: Tue Jan 27, 2009 9:05 am    Post subject: sony 3400v2 Reply with quote
the capacitor is installed correctly.but it is getting too much heat and the fuse blows off.
PostPosted: Tue Jan 27, 2009 12:02 pm    Post subject: Reply with quote
2) Exceeds Voltage Rating of Capacitor.
PostPosted: Tue Jan 27, 2009 2:45 pm    Post subject: sony 3400 v2 Reply with quote
I put a new capacitor which is mentioned in the circuit.In circuit it is mentioned c619(820mfd/250v).I replaced both the filter capacitor c618 and c619(820mfd/250v),but c618 is ok but c619 is getting heat immediately.
With Regards,
Ramji
LJ
PostPosted: Tue Jan 27, 2009 6:10 pm    Post subject: Reply with quote
I don't have schematics, wondering if you tell me, are both capacitor at regulator? are they both connected in series? is the resistor 330K parallel with the capacitor? if yes, try to check diode before capacitor, maybe it's short.
_________________
http://august-blog.blogspot.com/
PostPosted: Tue Jan 27, 2009 9:44 pm    Post subject: Reply with quote
Measure Voltage across C619? (If more than 250 WILL overheat)
PostPosted: Sat Jan 31, 2009 12:59 pm    Post subject: sony 3400 v2 Reply with quote
One capacitor c618 is charged through bridge rectifier circuit and the other capacitor c619 is charged through STR81145A(Voltage Doubler).This c619 is getting too much heat when powered on.
With Regards,
Ramji
PostPosted: Sat Jan 31, 2009 3:23 pm    Post subject: Reply with quote
What is the measured voltage across C619?
LJ
PostPosted: Sat Jan 31, 2009 6:26 pm    Post subject: Reply with quote
Possibility:
-Over voltage at C619 caused by:
* C at pin1 and pin2 STR81145A defective.
* STR81145A defective.
- Bridge rectifier defective ( pin - ).
_________________
