ramji Guest
Posted: Mon Jan 26, 2009 1:38 pm Post subject: HP L1702 TFT Monitor |
I have a Hp L1702 TFT Monitor.When I power on the display is good,but after 10 - 15 minutes the display goes and the front panel led in green colour.If i power off and on it again the display comes again,but the same thing happens after 15 minutes and after sometimes the display will come and go immediately if i poweron/off. need solution.
With Regards,
Ramji |
sflsan
Posted: Thu Jan 29, 2009 5:44 am Post subject: |
If the power light is still green and the display goes away, it is usually the inverter. When it goes out, can you still see a faint image? If not, try using a good flashlight and carefully press it all the way against the screen.
If you see an image on the screen, then the first thing to check would be if the inverter is getting the full 12 volts for power, and that the turn on lead is getting voltage as well. If the voltage is good and you're handy with a soldering iron, you can try replacing the caps and rewetting the transformer leads and see if that helps. |
pm2420 Philips • Model Number Format for WD Branded Produ • 63kv9617 philips • fdp20n50 fdpf20n50 Fairchild Semiconduct • CDM-7856R -7858 -7859 ALPINE • GC20-1619-8 EPL supl Dec70 IBM • 14 3000 Oct77 HP • [SMD] VS Series Cosonic • dsd1403004ce panasonic • HP 86140A Series User Agilent •
