Malik Guest
Posted: Sun Feb 08, 2009 12:25 pm Post subject: FX432M91 |
| AS PER NEW CODES, I HAVE REPLACED IC 8005.IT DID NOT WORK. |
arinc429 Guest
Posted: Mon Feb 23, 2009 5:26 pm Post subject: 10 blinks |
Sony asked 300 dollars to fix 10 blinking problem of TV kp-fx432M91.I decided to fix it myself on throw away basis, could not get much help for 10 blinks from Net. Bought Service Manual from net then few parts and finally above mentioned IC 8002 fixed the problem. Pls look for IC Part No. MCZ3001DB in D board, You will find two IC of same part number but look for the IC driving Two FETs of High Voltage Power supply section.
Q8013, Q8014, R8051 and IC 8002 are the essential components for HV section and these must be checked/replaced.
These all components cost only 12 Dollars in Middle East and 30 Dollars in USA and Sony may ask u minimum 250 dollars to fix 10 blinking problem. |
crina Guest
Posted: Tue Oct 27, 2009 12:52 pm Post subject: |
| I have Sony tv kv-29cs60k and the standby led blinks 14 times and does not switch on, anybody knows what is this?[/u][/b] |
[email protected] Guest
Posted: Fri Dec 04, 2009 9:28 pm Post subject: Re: 10 blinks |
| change ic smz in power supply |
lervinfix Guest
Posted: Sat Dec 05, 2009 3:39 am Post subject: |
sir/maam... sony has 10 blinks no video...just because the sysytem cannot detect the video signal came from video chroma or jungle ic.. thers a 3 ways to fix that..
1st......resolder the jungle ic.(if has a jungle ic..some tv has no jungle ic only in the sysytem controll)....resolder the crt board..if no luck try number option..
2nd....adjust the screen adjustment found in the flyback..(just a little bit)if no luck back the screen adjustment in previouse position then refer to option 3..
3rd......reset the memory ic found near of system controll ic..has 8 pins ..if you dont have a ic programmer gadget to reset the memory .. try pick up a memory to another junk tv.. only to test it if any development..(make sure you dont pick a wrong one..only memory ic with 8 pins near or beside of system controll ic..)some memory has a lable named ATMEL
hoped i can help.. |
Posted: Fri Jan 29, 2010 11:47 am Post subject: |
10 blinks means you have a problem in HV PROTECTION CIRCUIT, check and replace T8001,ic8002,q8013,8014,r8051 on D board or its line
