DaveC426913
Posted: Mon Feb 09, 2009 5:55 am Post subject: |
[Hmph. Didn't read me as registered.]
Hey I know it's been, like, 2 years but maybe someone's till around. I am following Sarcasmo's lead, pulling out the Hyper Module.
How can I get the board out? I see Sarcasmo has pulled the main board out with the hyper module attached. I can't seem to get the main board to come off the base. I've removed every screw I can find but it won't come out.
I thought maybe it might pivot out along one edge - left or right, but there are three edge connectors along the left side and two places along the right side where the chassis grips the PC board. One of those two edges has to be disconnected to remove the main board. Ideas? |
Posted: Mon Feb 09, 2009 10:42 pm Post subject: |
| If you look at the back side of the board you'll see 4 metal tabs you need to unsolder. Make sure all 4 tabs are loose before pulling out. Wiggle it back and forth. |
DaveC426913
Posted: Tue Feb 10, 2009 1:34 am Post subject: |
I got it out. Tooke me most of the day but I got it out.
Now I'm trying to solder the new caps back in. Actually, I'm first trying to pull the existing ones out. Not happening. |
Posted: Thu Feb 12, 2009 9:34 pm Post subject: |
I take solder wick and gently rock the smd caps back and forth. I replace them with electrolytic's. Screw the smd's. http://www.ptscorp.com/
Will also repair these mods. |
AdvaComp Guest
Posted: Thu Apr 09, 2009 11:27 pm Post subject: |
| would 10@35 work? |
Posted: Thu Apr 09, 2009 11:44 pm Post subject: |
| AdvaComp wrote: |
| would 10@35 work? |
A little big but yes. |
AdvaComp Guest
Posted: Thu Apr 09, 2009 11:45 pm Post subject: |
| Also would a Tantalum Capacitor work? |
AdvaComp Guest
Posted: Fri Apr 10, 2009 1:19 am Post subject: |
| Can anyone direct me towards a guide that lays it out plain and simple how to do this repair? |
Posted: Fri Apr 10, 2009 2:46 am Post subject: |
If you can convince them that you ARE a fellow technician, both Spyderman's forum and WA6ATI websites have detailed info...RepairWorld also - if you're willing to pay. Otherwise, try Google, etc.
Otherwise, most websites, even this one, (Searching for "hyper" produced 15 results) have a "search" box.
Of course, YOU still have to go through and READ them! |
shame516 Guest
Posted: Wed Oct 21, 2009 5:05 pm Post subject: 65hdx82 help bad |
| have a toshiba 65hdx82 had prblems with what seemed to be the covegence chjips but when i changed them put everything back and nothing all i get is a blue screen none of the inputs work but i have sound. Can someone pls send a pic of the boards inside tv set need to know if all wires are connected properly this would help me out a great deal thank you so much ... |
