Cicci79 Guest
Posted: Sun Mar 29, 2009 9:08 am Post subject: Acer AL718 LCD Monitor - Power supply Schematic Needed |
Hi everybody,
I need the schematic of The Power Supply of Acer AL718 LCD Monitor.
Can someone help me in this ? |
Posted: Sun Mar 29, 2009 5:23 pm Post subject: |
Just perform generic checks.
First make sure it has no blown/bulged electrolytics.
Are fuse(s) O.K.? Does main filter lytic have Raw B=Plus? Does Raw B=Plus make it to the regulator device? Does the regulator driver I.C. (and supply) have startup voltage and puts out drive signal to regulator? Do secondary supplies have correct voltage outputs (with or without loads connected)? |
Cicci79 Guest
Posted: Sun Mar 29, 2009 5:47 pm Post subject: |
Ok actually I think I express myself wrong.
I need the Inverter schematic ( the circuit which turn on the lamps ).
Actually power supply and Inverter are located in the same board.
Problem:
When I turn on the monitor the Transistor on the Inverter board starts to warm and after a while is burned.
The lamps turn on until the trasistor do not burn.
Thanks for helping |
CO16555 Atari Home Computer Technical Re • TEA2164S ST • TJ [radial thru-hole] GZ Series TJ [Tong • General EP2050 118 Minolta • 9 Vitek • 6870R6316AA LG • Инструкция AVR-2313CI DENON • FX71E1 Nokia • GPH5D TH-42PHD5 TH-42PHW5 panasonic • rireki panasonic •
