MARCOS Guest
Posted: Thu Dec 29, 2005 4:02 am Post subject: IBM 6400 |
NECESITO HACER EL AJUSTE DE FASE PARA UNA IMPRESORA IBM 6400 SI ALGUIEN ME PUDIERA AYUDAR
I NEED TO MAKE THE ADJUSTMENT OF PHASE FOR PRINTING IBM 6400 IF SOMEBODY COULD HELP ME |
jason Guest
Posted: Sun Jan 01, 2006 7:24 pm Post subject: phase adjustment |
dear marcus..
ibm 6400 is oem from printronix. All the hardware is same.
For phase adjustment, locate the phase number - usually written on the shuttle assy. Then goto diagnostic, select phase printer and enter the value as written in the shuttle. You must load an a3 size paper and let the printer print..it will print a line of e.g 064 HHHHHHHHHHHHHHHHHHHHHHHH
, check if the H is clear and not jaggered, enter value more or less until the you get a perfect H. - usually the phase value in the shuttle should be a correct value unless the shuttle been repaired before.
regards
jason
p.s you must activate the enter key by pressing UP & Down simultaneously. |
azumay Guest
Posted: Thu Feb 22, 2007 9:45 am Post subject: Re: IBM 6400 |
| Hola, primero tienes que saber que modelo es exactamente ya que hay varias 6400. Si fuera la 6400-050 para cambiar la fase tienes que sacarla de linea. y luego pulsar a la vez 4 botones que son empezando por la izq. los penultimos y los antepenultimos. Con esto accederas al menu especial que te permitira cambiar la fase, normalmente la fase suele ser 121. espero que te sirva de ayuda. |
GTaylor Guest
Posted: Tue Mar 24, 2009 7:36 pm Post subject: |
| How do you get to the diagnostics mode? |
Posted: Sat May 30, 2009 1:59 am Post subject: |
| Scroll up, scroll down, enter and return all at the same time. after pressing stop, then menu key |
