the_ccm Guest
Posted: Mon Aug 22, 2005 7:01 pm Post subject: LG Studioworks 775N / EV7001 (CA-65) doesn't start |
I've got a problem on a LG 775N monitor.
When I power-on the monitor, the power led goes on. A relay is clicking, I hear some noise as if the high-voltage is generated and then it stops. The relay is clicking and the power-cycle starts over again.
I check secondary voltages on SMPS, there is 4 lines : 75V, 160V, 6.3V and 15V. Everything seems to be ok except for 15V line which is only 11V , i thought one component were dead on the 15V line but couldn't find one ?? also on THT no -30V, -120V, -40V etc. also B+ transistor driver (IRF9530) is very hot after 30 seconds ...... |
the_ccm Guest
Posted: Tue Aug 23, 2005 7:26 am Post subject: |
Ok maybe this will help :
when "DPMF Low" is low, V1 equals to 15V and V2 nearly 0V, which is normal. But when DPMF is 5V, V1=11,2V and V2=11V. Output current on transistor collector is 0.33A , but even if i cut all after transistor output, and i place a 100Ohm resistor for example (0.15A), V1 fall down to 11,8V ??? D924 and C925 have been changed without success .................
Thanks for your help |
Posted: Mon Aug 29, 2005 10:12 am Post subject: I have same problem |
I Have same monitor too and also I have same problem too. Did you find any solution for this.
Thanks
Baris |
Posted: Sat Oct 15, 2005 8:08 am Post subject: |
check on crt bord their is any dry solder i found many time in 15 " |
Kulfi Guest
Posted: Wed May 31, 2006 6:47 pm Post subject: Problem |
Same Problem
did any one found any solution.
Thanks |
Posted: Tue Dec 25, 2007 5:08 pm Post subject: |
your FBT is gone. Change it |
Posted: Sun Sep 26, 2010 6:16 am Post subject: |
Same Problem
Thanks |
dvd 2015 roadstar • TV9.1 Schneider • 2sc2840 Sanyo • d 77 DUCRETET THOMSON • Sanyo DP42841 P42841-11 Z5VK [SM] Sanyo • PM EP2050 027 Minolta • TX901 Onkyo • Panel CMO V420H2-LH2 0 [DS] . Various • 2951_Test_Structure_Design Keithley • psmn1r0-30ylc Philips •
