BillW Guest
Posted: Fri Jun 19, 2009 8:32 pm Post subject: Inputs |
| Using inputs for both Video. Cable co finally connected wire back to post and appears to be working with Tuner. |
BillW Guest
Posted: Sat Jun 20, 2009 1:36 am Post subject: Re: Inputs |
| BillW wrote: |
Sorry, I wasn't very clear. The intermittent video seems to be with the video inputs. My cable company had disconnected the feed to the house while rewiring and I could not check tuner input until this afternoon. So the problem persists with the signal from the AV.
Bill |
Posted: Sat Jun 20, 2009 3:58 am Post subject: |
| Hit the menu button on the remote if you loose the picture, it will lead you towards a signal problem or set problem. If you loose picture and press menu and it comes up its not the set. |
BillW Guest
Posted: Sun Jun 21, 2009 1:10 am Post subject: Menu still works |
Minnie,
Tried pressing the menu button while the set was on tuner and picture stayed in background. Tried it while on the video input and still get a menu, with the black screen. Audio seems to be coming throught from DVD player without any issues. Just getting black video screen. Double checked cable to make sure that all cables hooked to correct location on both ends. Seems like something must have gone after replacing the two bad components. Is the red light supposed to remain lit after the repair? Can't see any other LED's that are blinking or going out after powering up and the Video feed side was working prior to the bad cap and fuse.
Thank you again for your input and help.
Bill |
Posted: Sun Jun 21, 2009 6:03 am Post subject: |
| Sounds like a source issue. If menu comes up the set is working... |
Posted: Sun Jun 21, 2009 11:05 am Post subject: |
DVD players can break. Cables can fail.  |
Frankk Guest
Posted: Wed Jul 08, 2009 2:15 am Post subject: Hitachi 50UX52B |
| I have the issue with a set that turn on, and shuts right back off. The red protect LED flashed and originally, the 120V LED did not illuminate. I replaced E994 (it was open), and C707. Now the symptoms are the same, but the 120V LED does light up. Any suggestions? |
Posted: Wed Jul 08, 2009 4:00 am Post subject: |
I'd be replacing the convergence IC's next.
minnie |
Frankk Guest
Posted: Wed Jul 08, 2009 11:27 pm Post subject: |
minnie |
Thanks, do you happen to have the part numbers? Should I replace the resistors for these IC's also? Thanks! |
Posted: Thu Jul 09, 2009 12:23 am Post subject: |
| What, you don't like surprises? |
2sc3318 Inchange Semiconductor • samsung np x11 . Various • 3250 Marantz • TPM5.3E la Philips • 1 00021-1 FEA209544 21UEN B Ericsson • AltoSWRef.part2 xerox • 712156 03-12 panasonic • bfm520 2 Philips • 2sc3870 Panasonic • AV-32WL1EI JVC •
