donz Guest
Posted: Wed Feb 14, 2007 8:48 am Post subject: A solution for the Acer AL1511 "no signal" blackou |
Hi y'all. I think this might resolve the problem...
On the Acer AL1511 are some control buttons (AUTO < > MENU). After booting up, I used the MENU and <> buttons to get to the OSD settings. I changed the "OSD Timeout" from 20 to 50, and since then have not had the blank "no signal" screen during startup. Hope that helps! |
SZASZ
Posted: Fri Apr 27, 2007 2:08 pm Post subject: SCALEO |
About the Fujitsu LCD scaleo the fault is the inverter.The inverter is placed same with power board. Sorry, I have occurred this fault and replaced the module I cannot advise you about exactly what part is damaged.
Szilard. |
gutycort Guest
Posted: Fri Aug 14, 2009 9:57 pm Post subject: Re: Workaround on ACER AL1511 |
[quote="donz"]Hi. I have the same problem with Acer AL1511 monitor on AcerPower F1 PC. It initially appears to start up fine then goes blank with a "No Signal" message display. I am able to prevent this from happening by constantly jiggling the mouse (small movements back and forth) during startup until the logon is displayed. It's a pain and I'd love to know how to FIX it.[/quote]
Connect the monitor in a computer in safe mode and check if the problem persists. Check the frequency= 60Hz |
Posted: Fri Nov 20, 2009 5:36 pm Post subject: Re: Workaround on ACER AL1511 |
| donz wrote: |
| Hi. I have the same problem with Acer AL1511 monitor on AcerPower F1 PC. It initially appears to start up fine then goes blank with a "No Signal" message display. I am able to prevent this from happening by constantly jiggling the mouse (small movements back and forth) during startup until the logon is displayed. It's a pain and I'd love to know how to FIX it. |
check cable between your monitor and PC or better found new cable. |
