jlmclean
Joined: 20 Dec 2008 Posts: 7 Location: North Carolina, USA
Posted: Mon Oct 05, 2009 1:26 pm Post subject: Sony HCD-RXD6AV Question |
I am trying to find the belt numbers for the tape drives on a Sony HCD-RXD6AV home stereo system. I have the service manual but for some reason there is no info on the drive belts for the tape decks. I found a site where I can order the belts but they list 5 different numbers and there are only four belts and I just need two of them and at $15 ea. I want to make sure I order the correct ones. On each deck, there is a small square belt that goes from the motor to ONE drive wheel. I have them and they are in good condition. There are also the two flat belts that are longer and they go around the two large drive wheels. On deck "A" it goes around the motor and two large drive wheels and two idler pulleys that help direct the belt and on deck "B" it just goes around the motor and the two large drive wheels. These two belts are the ones that I need the part numbers for. If anyone can help, please let me know.
In the manual it says that HCD-RXD3 uses a similar tape deck.
Thanks
Jerry |
Boggs
jlmclean
Posted: Mon Oct 05, 2009 6:43 pm Post subject: |
Boggs
Those are the same part numbers that I had found. This bulletin does eliminate the 403 as it's for a different machine. I'm thinking the first two listed, the 400 and 401, are the two I need but I really need a parts breakdown with the picture of them to make sure. I guess when my service manual was printed, the only option you had was to replace the whole unit. It shows no breakdown of the tape deck at all. Do you have any idea what the abbreviations in parenthesis stand for, the BFR, AFR, BR, AF, and AR? I feel sure the A and B stands for deck A and deck B but I'm not sure about the others.
Thanks for the bulletin. I printed it and added it to my manual.
Jerry |
