ponytailedgrl
Posted: Tue Oct 06, 2009 5:29 pm Post subject: Test/Measure Transformer |
I have a transformer on a circuit board of my GE range. I'm measure 110AC on the pimary side but on the secondary side there are 4 pins, marked 5,6,7 and 8. It should have 24 DC volts coming out of it. From what I can remember in one of my undergraduate class, the 2 pins on the primary measure 110 AC and the secondary should have 2 wire that read 24 DC. I have 4 pins coming out of the secondary. Two that measure 11 while the other two pins have 24. This is measure under a load. I did check the resistance it was okay. Any suggestions to testing the transformer? |
Posted: Tue Oct 06, 2009 9:18 pm Post subject: |
Voltage at transformer "pins" is always AC.  _________________ You're over there, I'm over here. |
Posted: Tue Oct 06, 2009 11:29 pm Post subject: |
Always? Sweetie I thought I had located a replacement part that had 24v for the secondary winding. Does that explain why there are 4 connections out of the secondary? Taking it from AC and turn to DC by way of some diodes on a connected board? Then it seems to run back to the original board to some relays. and then back to the transformer? |
Posted: Wed Oct 07, 2009 12:08 am Post subject: |
Just because a transformer has a mess of pins, does not mean it has to use all of them.
AC out of transformer can be rectified by one diode (half-wave) or by two diodes (full wave). It can also be rectified by four diodes (full wave bridge). _________________ You're over there, I'm over here. |
Posted: Wed Oct 07, 2009 5:01 am Post subject: |
One "set of pins" has 24vac while the other has like 3vac. What is happening is the relays are switching back off after a few mintues. The coil will energize and the oven will get hot but then a few mintues later the relay cuts off? Does that sound like a leaking e-cap or a bad diode? |
1973-08 Agilent • DVD-3910E2 E3 D.LINK3RD DENON • an 70 HP • blk004 panasonic • CQ-RD325LEN Panasonic • TCC-67~1 LG • Panel CHIMEI INNOLUX M236HGE-P02 0 [DS] • M629, M679V Sony • sts9nf30l . Electronic Components Datash • 902 HP & FWB RMS Schematics . Various •
