Yamaha RX-V650 won't power on
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
elekos
PostPosted: Sun Oct 18, 2009 9:32 pm    Post subject: RX-V650 power on-off problem Reply with quote
C405 capacitor is very important to proper standby voltage. Install new , even if original looks fine. By the way- on the C406 should be not less as 7.00 VDC, and sometimes add extra capacity to the C411 will help. For sure, check all ground connections, especially on the main and on the DSP module. Smile
thiPo
PostPosted: Mon Oct 19, 2009 6:13 pm    Post subject: Reply with quote
I don't have much time to try to fix mine, but when i look for C405, C405 and C411 are on the "sub trans PCB".
C405 is a PP capacitor (polypropylene??), with a capacitance of 0,022µF and a volatge rating of 630V.
C406 is an elco with a capacitance of 1µF and a rating of 50V
C411 is an elco as well, with a capacitance of 3300µF and a rating of 16V.
Are these the ones you mean?
Is the problem C405 measurable in the circuit, or do I have to desolder them and measure then?
Ancoor
PostPosted: Thu Nov 12, 2009 4:28 pm    Post subject: Re: RX-V650 power on-off problem Reply with quote
Thanks Elekos and thiPo... I had these exactly symptoms with no power and with the "flickering" dim blue "direct" button on my RX-V650. I purchased the 3 capacitors according to elekos list above for approx $2, but needed only to replace C405 before it started to work again.
I couldn't test all ground connections, because I don't have the service manual.
I haven't yet fully tested it all warmed up, and with everything attached, but I'll let you know if the problem turns up again.
HUGE THANKS! Smile
ThiPo
PostPosted: Mon Nov 16, 2009 8:33 pm    Post subject: Re: RX-V650 power on-off problem Reply with quote
Where did you purchase your PPcapacitor? I can't find a shop which sells one with a right footprint.
HUGE THANKS! Smile
Ancoor
PostPosted: Mon Nov 16, 2009 9:43 pm    Post subject: Reply with quote
I'm lycky enough to have this resellers shop around the corner from home in sweden. Smile
https://www1.elfa.se/elfa~eu_en/b2b/start.do
Choose the country closest to you...
The largest they have (I think) is a footprint of 7.5 mm, part number 65-562-11. I bought a 5 mm, and it was not the right footprint (as you describe yourself) but I did use a small extra cable extension. Check if 7.5 mm is enough.
The 2 electrolytes I bought, but never replaced, was...
c411 - 3300 uF/ 16V - part number : 67-012-13
c406 - 1 uF / 50V - part number : 67-013-12
Note, I haven't really had the time to fully reconnected everything yet for complete testing. Wait a few days, and I'll check that everything seems "ok".
Ancoor
PostPosted: Mon Nov 16, 2009 11:36 pm    Post subject: Reply with quote
ThiPo, 65-562-29 should have the correct footprint...
22nF/630V 10mm
ThiPo
PostPosted: Tue Nov 17, 2009 2:06 pm    Post subject: Reply with quote
My local electronics store can order the same: Evox Rifa PHE450MB5220JR06, 22 nF – 630V Dimensions: 5.5x10.5x18mm - pitch: 15mm
Minimum 5pcs at €0,5 a piece.
I'll wait to order them until you confirm that everything is working again!
I can mail the other 4 to people who can't find the right one near their location.
Ancoor
PostPosted: Tue Nov 17, 2009 10:48 pm    Post subject: Reply with quote
I've tested it since yesterday for approximatly 6 hours. Everything seems ok. All inputs "ok", loudspeakers "ok". Several tests to start from standby without any problems and everything is now connected.
ThiPo
PostPosted: Wed Nov 18, 2009 9:49 am    Post subject: Reply with quote
I've ordered the capacitors.
I'll report if my receiver has been fixed.
ThiPo
PostPosted: Sat Nov 21, 2009 1:51 pm    Post subject: Reply with quote
My receiver has been fixed as well by replacing C405 (PPCap)!
Page 3 of 8
