silverfox Guest
Posted: Fri Oct 16, 2009 1:41 pm Post subject: Fiat idea radio probs |
| The radio on my Fiat Idea has started switching itself on when either the ignition is on or not, thus running down the battery. I changed the battery, not knowing about the radio, and tho it appears to work OK, its started switching on when turned off. Any ideas. sorry for the pun. |
clint Guest
Posted: Sun Nov 08, 2009 8:46 pm Post subject: radio |
I have just bought an idea, i don't have it yet but i have been reading up about it and i understand the radio problem is common, apparently there is a micro switch that controls the cd which sometimes mistakenly thinks a cd has been inserted thus waking up the radio and flattening the battery. apparently the quick fix is to leave a cd in the slot.
Hope this helps. |
Posted: Mon Nov 09, 2009 2:35 am Post subject: |
If the radio is running the battery flat, you must not use that Fiat very much (or unit comes on at Full Volume). Normally will take a number of DAYS or weeks to drain fully. _________________ You're over there, I'm over here. |
SUGENK
Posted: Sat Nov 28, 2009 8:12 am Post subject: |
| maybe something wrong with the cabling connection of B+ of your radio to the source. Better you check and follow the diagram ( it usually found on the top of the radio case. |
Panel SAMSUNG LTM240CS09 0 [DS] . Variou • Figures36373839-BrushPercussionPedalGate • ve nc 510 service cz TESLA • philips lc 4031 hopper sv10 Philips • TX7000 Onkyo • Der Braun-Sammler Braun • msi_a6200_ms-1682_rev_0b_sch MSI • B53-0165-00 Kenwood • 445pro-hp p1110 NOKIA • XA-003[1].part2 AIWA •
