The_AntiRAM Guest
Posted: Sat Nov 28, 2009 9:27 pm Post subject: |
Basically it's enough.
To know wich panel is fitted in your plasma you have to read it inside
not on the out side printed custom sticker.
You have to dismount the PCB boards and find where is written in the back
of the panel.
There should be a side where the complete code of the panel is printed, inclusive the needed "V" (Version of Development).
Anyway the matched coded of the boards should be sufficient.
(At the end it's a Samsung Display wich is commonly employed Even in PHILIPS).
The important thing is that boards SHOULD MATCH EVERYTHING NEEDED. |
The_AntiRAM Guest
Posted: Sat Nov 28, 2009 9:34 pm Post subject: |
| jts1957 wrote: |
Fred Flintstone only uses two wheels.
Funny,
I dislike drive these "cars", they are too "hungry" of "Servo Steering"
vaio
Posted: Sat Nov 28, 2009 9:42 pm Post subject: |
I found this : )
My is V4 . |
vaio
Posted: Sat Dec 05, 2009 1:51 pm Post subject: |
Answer for my previously question about logic board compatibility !!!
The LJ41# is the designation for the raw unpopulated board before components were installed and I never advise using that number for part ID.
The LJ92# is the one you need to use to identify the correct part number. The alpha character at the end has to do with additional modifications.
These boards are to be thought of as forward compatible, meaning you can replace an “A” version with a “B” version however I would not advise replacing a “B” version with an “A” version. Basically considering any of these parts as backward compatible is not advised.
Concerning the A/B/C/D…. scenario, if none of the alpha characters have a circle, slash, marked out or otherwise indicated, consider it an “A” version. |
