alanfryer Guest
Posted: Tue Jan 26, 2010 1:02 pm Post subject: Philips MX3800D Turns self off |
I have A Philips MX3800D dvd player, after about half hour or so of playing a DVD it turns itself off and then about 10-15mins later the power is returned. I'm guessing its something overheating on the power PCB but unsure.
Does anyone have any ideas? |
Posted: Tue Jan 26, 2010 1:37 pm Post subject: |
Or bad caps, or bad laser assembly, or etc., etc. _________________ You're over there, I'm over here. |
alanfryer Guest
Posted: Tue Jan 26, 2010 2:13 pm Post subject: |
| I think i may have narrowed it down to the main PCB in the player as when it is turned on and off at the wall the standby light comes on and when pressed the light goes of as if turned on but then the screen is still blank, then after 5 mins the screen returns. |
Eugene Murray Guest
Posted: Tue Aug 02, 2011 3:22 pm Post subject: Re: Philips MX3800D Turns self off |
| alanfryer wrote: |
sure, i can help you. Dont be sad. U can fix this problem yourself. The problem lies with the main power IC in the power supply stage supplying voltage to the mother board. It needs changing with a good quaility one. It is a 6-leg standup IC. In my dvd player it is numberd TOP249y. since this get faulty it shuts down automatically. your right basically an overheating problem with this IC. While replacing this IC make sure that the back of ic is correctly up against the heatsink with proper heat sink compound. Be careful not to damage the printed circuit behind. Do the part chaning carefully. |
gilles.perpignan Guest
Posted: Wed Aug 03, 2011 9:13 pm Post subject: Re: Philips MX3800D Turns self off |
Thanks.. I have exactly the same problem and its obvious that this TOP249y is the cause! but please where did you find the replacement one, and which price?
Thanks [email protected]
| Eugene Murray wrote: |
| alanfryer wrote: |
