Rikki Guest
Posted: Thu Jul 02, 2009 11:14 pm Post subject: Pico Fuse |
Hey I have got the same problem with my HP 1530.
I think i have located the pico fuse. Its black has no markings?. Anways it has a code next to it FP751. What does this mean?.
The tech shop has pico fuse with the code FP2 which is 2A and also FP750 which is 750mA. Which one do i need? A 2A? Does the code by the fuse matter?.
All help will be appreciated.
Thanks. |
Rath_Cambodia Guest
Posted: Fri Oct 30, 2009 4:33 pm Post subject: All your threads are value for me |
HI Guys,
I got the same trouble on hp 1530 too, i found the back light came out for a second and turn off itself and no back light lit out any more. However, I could see the shadow of message { NO CABLE CONNECTED } appear.
So could any one tell me to identified and replace the bad ICs on Board....
Thanks and Appreciate for all help.
Rath, |
cattledrover
Posted: Thu Nov 19, 2009 2:53 pm Post subject: Same problem as Rath |
Guys,
Rath has described my problem exactly please sent help.
Cattledrover |
Posted: Thu Nov 19, 2009 3:12 pm Post subject: |
You all may want to check out Dell FP152 / FP172 series posts, here and elsewhere. Bad joints on transformers / shorted transistors & FETs along with the pico fuse already mentioned.  _________________ You're over there, I'm over here. |
Paps Guest
Posted: Mon Jan 04, 2010 12:01 pm Post subject: |
Hi i have the same problem as some.
HP 1530; Model: PE1236
When i turn the monitor on green light comes on and when screen lights up it turns off and it does that on and on. I never see anything on the screen. I checked fuse and its good. Changed 4 Brown Capacitators and didnt help.
Here is a picture of the circuit, if anyone can help me out.] |
Paps
Posted: Mon Jan 04, 2010 12:06 pm Post subject: |
| Paps wrote: |
paulanderson1548
Posted: Sat Jan 30, 2010 11:50 am Post subject: hi |
| i think chasing pico fuse on the backlight side of circuit. now is working great! |
Posted: Sat Jan 30, 2010 4:47 pm Post subject: |
| Paps wrote: |
| Paps wrote: |
How many of the lamps are broken or burnt out? _________________ You're over there, I'm over here. |
Posted: Wed Feb 24, 2010 3:36 am Post subject: |
| Paps wrote: |
1,HV circuit damage,that would lead powerboard protected.
2, signal circuit have broken point,signal missing.
sorry for my poor english.
good luck |
joekei Guest
Posted: Wed Nov 24, 2010 1:45 pm Post subject: |
| thanks 4 the advice but my question is does the replacement require unsoldering and resoldering or just mere fixing? |
