MIKEOMZ1 Guest
Posted: Wed Dec 21, 2005 11:45 pm Post subject: CD READING PROBLEM |
| HI ..I HAVE A JVC COMPACT COMPONENT SYSTEM. MX-G700R.IT IS A THREE CD SYSTEM..IT WILL NOT RECOGNISE ANY CDS IN THE TURNTABLE AT ALL..I HAVE TRIED A CD LENS CLEANER TO NO AVAIL..CAN ANYONE HELP ME.EVRYTHING ELSE IS WORKING PERFECTLY..THANKS .MIKE |
Posted: Thu Dec 22, 2005 12:49 am Post subject: |
| THE PICKUP IS PROBABLY U/S BUT IT MIGHT BE WORTH CHECKING THE SPINDLE MOTOR FOR BEING SLUGGISH, A GOOD SPINDLE MOTOR SHOULD HAVE A RESISTANCE OF APPROX 14 OHMS. |
MIKEOMZ1 Guest
Posted: Thu Dec 22, 2005 4:34 am Post subject: CD READING PROBLEM |
PART 2
IT IS NOW PLAYIN SELECTIVELY AT RANDOM .AND THEN NOTHING AT ALL.COULD YOU BREAK IT DOWN AND SIMPLIFY WHAT YOU THINK IT COULD BE ,TO ENABLE ME TO OPEN IT UP AND HAVE A LOOK .IF ITS NOT TOO MUCH TROUBLE.IAM NOT FAMILIAR WITH (U/S), OR (PICK UP), OR (SPINDLE MOTOR)..MAYBE I SHOULD JUST TAKE IT TO THE REPAIR SHOP.BUT I LIKE TO FIX THINGS AND WOULD LIKE TO LEARN IF I CAN...CHEERS.MIKE |
sparky
Posted: Thu Dec 22, 2005 4:51 am Post subject: CD READING PROBLEM |
The other gent meant the laser assembly or the motor that spins the disk as being under suspision.
You could try a DVD cleaner rather than a C.D cleaner disk though as I had a similar problem in my car recently and could not be bothered to remove it as it is built in. The C.D cleaner did not work and tried a DVD one instead and this did the trick with a little isopropynol (c.d cleaner fluid) on the pads on the cleaning disk. The DVD one had much chunkier pads containing brushes and made a better job of cleaning the laser but only use for a short time as the C.D will spin like the devil due to the fact it does not recognise the disk. _________________ If in doubt pull the plug out. |
MIKEOMZ1 Guest
Posted: Thu Dec 22, 2005 5:02 am Post subject: CD READING PROB. |
| CHEERS SPARKZ.I'LL GIVE THAT A TRY.THANKS.MIKE |
MIKEOMZ1 Guest
Posted: Thu Dec 22, 2005 6:27 am Post subject: CD READING PROB |
| ANY OTHER SUGGESTIONS WOULD BE RELLY HELPFUL ALSO??..CHEERS |
