wjd03
Posted: Fri Feb 26, 2010 12:03 am Post subject: too short flyback wire repair |
ok all, need some help here, i am catching a devil of a time getting the red flyback wire to catch. had to take it out several times to check soldered pins. now i cant get the darn thing(red lead) to catch, and afraid it is getting to short!!!
help |
Posted: Fri Feb 26, 2010 1:11 am Post subject: |
Brand/Model/what trying to "catch?" _________________ You're over there, I'm over here. |
wjd03
Posted: Fri Feb 26, 2010 1:25 pm Post subject: |
| Sorry I should have been specific, Its the RCA D52W19 I have been working on. The flyback (red) wire is getting short from trying to ckech board for poor soldering. Any ideas? |
Posted: Fri Feb 26, 2010 11:15 pm Post subject: |
| I've used tooth picks and silicone when I had too. |
wjd03
Posted: Sat Feb 27, 2010 12:11 am Post subject: How? |
| Thanks Minnie, but how did you do that? When I try to send the wire in the shoot to the bottom, it wont stay, it used to seat in the proper pin hole but now I am getting the same power problems as before (before I replaced the flyback). I have ordered another flyback because I had the power back on before I had to remove the cables and flip the board and check solder joints. Any ideas? or will a new flyback be a better solution? |
Posted: Sun Feb 28, 2010 5:36 pm Post subject: |
| The catch in the flyback might be shot, 240966 is the part # for a new anode lead. |
wjd03
Posted: Sun Feb 28, 2010 10:25 pm Post subject: fixed it |
| This is so amazing!!!! I fixed it! Nice picture clean, after a convergance adjustment. I ordered a new Flyback but I wanted to give the other (new ) one -one more try. I found that the Red wire going into it had broken wherer it seats inside. I had to drill a hole through the long insulator to see it , pulled it out and seated the wire back into it, and wala! But as I thought might happen, voltage is slipping out. I need to put epoxy where the drill hole is to seal it and I am done. I would like to thank everyone who guided me through this from what to look for to the right parts to order. This is awsome! |
