Albardeiro
Posted: Sun Feb 28, 2010 3:41 pm Post subject: Mitshubishi TV shaking picture |
My Mitsubishi TV VS-50705 started with shaking picture some time ago, it would go away after but got longer and longer, I red that it could be the PIP board and could be bypassed, but when I opened the TV I didn't see anything that looked like the 903B552 board (my TV is a 1999 ) so I red some more and someone point out that the SMV 935D3910 board was the PIP board. I order one but toke that board out to check for bad caps or so and for the hack of it I pluged the tv back on and started it again and for a couple minutes it worked fine ,then started to shake againg leadding me to believe that that is not the problem and possible not the PIP board.
Any help
Thank you |
Posted: Sun Feb 28, 2010 5:48 pm Post subject: |
| Check/replace c2p05, C2P02, and C2P03 on the signal board. c2p05 is usually the bad one. Their the filter caps for the regulators. |
Albardeiro
Posted: Mon Mar 01, 2010 8:33 pm Post subject: |
As I was trying to find c2p05 and so on ( still didn't) I had the tv unplugged from power, later when I plugged it back to power and turn the TV on it was fine for about 5 minutes then it starter to shake any more information would be grate.
Thank You |
Posted: Tue Mar 02, 2010 1:52 am Post subject: WRATH |
| Did you replace the mententioned part? If not why not? |
Posted: Wed Mar 03, 2010 12:38 am Post subject: |
| jts1957 wrote: |
He says he can't find it, therefore it doesn't exist. Wants to move forward.  |
It's there. Look next to the transistors on the heat sinks. |
Posted: Thu Mar 04, 2010 12:03 pm Post subject: |
I finally removed the signal board from TV and found the caps you were talking about, I replaced c2p05, c2p02, c2p03 and since I had order it I also replaced the IC2p01(9v regulator). Put everything back and IT WORKS GREAT, toke me about an hour from removing board to finish.
Thank you MINNIE |
Albardeiro
Posted: Thu Mar 04, 2010 12:49 pm Post subject: |
I didn't realize that I wasn't logged in
Thank You |
ChadCy75 Guest
Posted: Fri Apr 23, 2010 7:57 pm Post subject: where did you get parts? |
| Does anybody know where to get the C2po5? |
