ghartman
Posted: Fri Jan 06, 2006 12:44 am Post subject: Magnavox 20MT1331/17 |
I have this Magnavox 20" TV and when you turn on the TV there is a black screen - no picture, no sound. In fact there is very little indication that the set is turn on - maybe a slight click. Took off the back - fuse is not blown. Any ideas on what to do next, what to check for or where I can find a schematic? One of the electrical techs here at work thinks it might be one of the transistors but won't look at the TV without a schematic. The set is a little over 1 year old so it is beyond its warranty period.
I appreciate any insight you can give me!!
Gary |
Sammy Guest
Posted: Tue Jan 10, 2006 2:52 pm Post subject: Just a click, otherwise set is dead |
Check your horrizontal output transistor, flyback transformer, low voltage
fuse in the power supply. The horrizontal output transistors are the
most frequent cause of high voltage shutdown- dead set or mabe just the
led that tells you the set is on. |
ghartman
Posted: Tue Jan 10, 2006 10:08 pm Post subject: Electronic components |
Can you give me some insight as to where these components are located? I tried Sam's PhotoFacts and cannot find the schematic.
Also, the low voltage fuse checked out okay - that was the first item I tried to find and locate since it would be the "easiest fix".
Thanks |
