ruijorgemoreno Guest
Posted: Thu Apr 01, 2010 5:36 pm Post subject: Sony dsc-w7 fuses and flash error |
Hi!
I need your help people!
I had to change one of the main fuses on my Sony dsc-w7 but now I can't locate the flash fuse!
Can anyone help?
By the way, the camera is giving error: E:91:01.
And yes, I already reset the camera.
The camera works fine but when I select "flash on" it tries to charge the flash and then it gives me that error.
Thanks in advance.
RJ. |
ruijorgemoreno
Posted: Thu Apr 01, 2010 5:47 pm Post subject: |
I also have the service manual, level 2, but unfortunately it doesn't have any schematics that show parts placement...
RJ. |
ruijorgemoreno
Posted: Sun Apr 04, 2010 8:03 pm Post subject: |
Can anyone please help me to identify this component?
Thank you.
RJ. |
Posted: Mon Apr 05, 2010 3:59 am Post subject: |
| It appears to be a surface mount fuse. (Do remember Sony using the 32V surface mount fuses on many of their products. Not sure of the amperage value but you could always try 1.5 to 2 A pigtail in its place for testing purposes. what do you read across the device? (ohmwise) |
ruijorgemoreno
Posted: Mon Apr 05, 2010 8:25 pm Post subject: |
Thanks for your reply.
I got it.. It's a diode.
Called D851 in the service manual..
The problem now is that the service manual doesn't tell it's specs...
So now I'm stuck...again..
RJ. |
ruijorgemoreno
Posted: Mon Apr 05, 2010 8:50 pm Post subject: |
This is the broken diode...
Can anyone help, please?
Thanks.
RJ. |
Posted: Tue Apr 06, 2010 2:05 am Post subject: |
D851 is a fast recovery 800V .5A diode, Generic part#:CRF02 made by Toshiba
ruijorgemoreno
Posted: Fri Apr 09, 2010 9:23 pm Post subject: |
Thank you so much!!
Do you think it's safe to use a diode with more voltage specs?
Thanks again.
Rui. |
Posted: Sat Apr 10, 2010 4:39 am Post subject: |
| ruijorgemoreno wrote: |
Thank you so much!!
Thanks again.
Rui. |
You can always go with higher breakdown ratings provided there is no space issues involved but, try to keep the switch timing as close as possible. |
ruijorgemoreno
Posted: Mon Apr 12, 2010 7:00 pm Post subject: |
Thanks again for the replies.
One more question...
Do you have any idea where to buy this in europe?
I can only find this little beast in toshiba semicon's website...
Rui. |
