Posted: Wed Dec 01, 2004 11:42 am Post subject: Capacitior help! |
I need to replace two capacitors in a TV that i can see are visibly leaking,i've replaced all the other leaking ones but i can't find a match for these two :- 1500uF/25v & 470uF/6.3v. Is is OK to up the working voltage of capacitors? eg,fit a 1500uF/50v instead??Thanks for any help....... |
dvidov27 Guest
Posted: Wed Dec 01, 2004 7:31 pm Post subject: voltage |
Voltage written on the capacitor body is maximum voltage . So it is OK to put capacitor with higher voltage vallue . Only problem is that higher voltage capacitor needs more space , but in TV set should be enough space . Bye |
Atom
Joined: 26 Nov 2004 Posts: 29 Location: Tennessee, USA
Posted: Thu Dec 02, 2004 4:23 pm Post subject: Re: Capacitior help! |
Anonymous wrote: |
Yes. _________________ visit Singles Places dating site
Posted: Sat Jan 14, 2006 11:34 pm Post subject: Re: Capacitior help! |
Anonymous wrote: |
.YES IT'S OK TO USE HIGHER VOLTAGE |
Posted: Sat Jan 14, 2006 11:35 pm Post subject: |
Posted: Sun Jan 15, 2006 1:39 am Post subject: |
For a T.V. use high temperature (105 Degrees C) capacitors. If they are in a high frequency circuit, use high frequency (Low ESR) capacitors. If they are near hot things, lean them away from the heat or mount them under the board.
Good Luck! |
TP17LS7TSB Samsung • Aficio 2000 ricoh • tk8a55da 100406 Toshiba • 2sc3345 Toshiba • KF Series 1767828587 Capxon • bdx87 a b c Inchange Semiconductor • HP E4406A VSA Data Sheet Agilent • Beko 12 8 BEKO • Amroh UN39 AMROH • 50 ic 101 Philips •
