nicebreed Guest
Posted: Mon May 24, 2010 1:31 am Post subject: 42 vizio plasma vp422hdtv10a no picture |
Hi, if any one can I need some help. my viz lost its picture, but retains the sound. I have checked some blogs and read that its probably the backlight inverter. After research I cannot find a component that matches any board in the television. do plasmas not have one? and any suggestions for trouble shooting. limited knowledge in this area. Any help would be awesome! Thanks!  |
Posted: Mon May 24, 2010 4:02 am Post subject: |
No, they do not. _________________ You're over there, I'm over here. |
nicebreed Guest
Posted: Mon May 24, 2010 7:04 am Post subject: |
| Thank you! I shall stop looking for one then. Do you by chance have any suggestions? |
Minimess
Posted: Mon May 24, 2010 6:21 pm Post subject: Re: 42 vizio plasma vp422hdtv10a no picture |
| nicebreed wrote: |
Plasmas do not have backlight so there should be no inverter. Check out the connections to see if anything is loose. How long have you had this TV? |
nicebreed Guest
Posted: Wed May 26, 2010 3:50 am Post subject: |
| not long. picked it up from the pawn shop in as is condition. I like to tinker on things and learn so I tore into it |
nicebreed Guest
Posted: Thu May 27, 2010 6:31 am Post subject: |
| all connections appear to be wound. I unplugged each buffer board one at a time and no change. The led vizio light turns on, can hear the relays click on the power board, don't smell any magic smoke, nothing appears to be overheating. any other ideas? logic board perhaps? oh, there is a blinking green light when I turn the television on, on the logic board. Is it supposed to blink or stay solid green? Thank you so much! Toby |
Posted: Thu May 27, 2010 9:08 pm Post subject: |
| Have you checked the VS and VA voltages out of the power supply? |
nicebreed Guest
Posted: Fri May 28, 2010 2:48 am Post subject: |
| limited tools. can I use a multi meter with out causing more damage to the components? |
nicebreed Guest
Posted: Sat May 29, 2010 8:06 am Post subject: |
| thanks for our help going to the dumpster |
Minimess
Posted: Mon Nov 01, 2010 9:23 pm Post subject: |
| nicebreed wrote: |
Sad to hear that mate  _________________ Next day ink | Mailing Services |
