[email protected] Guest
Posted: Fri Jul 30, 2010 8:44 am Post subject: Why do electrolytic capacitors keep failing |
| I have a DVD/hard disk recorder (Sansui DVR5013H) that keeps failing. It freezes up or won't turn on. I have fixed it about 5 times in the past by replacing bulging electrolytic capacitors in the power supply but it keeps happening every few months. What are the common causes for electrolytic capacitors to keep failing in this way? I have already replaced all of the physically larger capacitors in the power supply but haven't replaced the small capacitors. |
Posted: Fri Jul 30, 2010 9:49 am Post subject: |
Are you replacing electrolytics "like with like" in regards to ratings, or are you upgrading to higher?
Are power supply voltages within spec?  _________________ You're over there, I'm over here. |
Posted: Fri Jul 30, 2010 12:25 pm Post subject: |
| Replacing with the same values, although the originals were 85 degree and I am now fitting 105 degree. The output voltages seem fine. Should I replace with higher voltage caps? |
Posted: Fri Jul 30, 2010 5:06 pm Post subject: |
If an edge connector has a pin that's marked 12V and you're measuring 24V, I'd check that out 1st.
85 to 105 is good. _________________ You're over there, I'm over here. |
LaserPrinter 4039 Lexmark • phb30nq15t php30nq15t 1 Philips • Laser Jet 2200 HP • 2n3719 Microsemi • bdt92 94 96 Inchange Semiconductor • BX553A Philips • 09 Troubleshooting Samsung • bk02 power1 panasonic • HP COMPAQ BUSINESS NOTEBOOK NX7000 SM Co • 74121 datasheets •
