Forman Norman Guest
Posted: Tue Sep 01, 2009 7:57 am Post subject: Thanks for great advice |
Hade the blinking red light on my ds65 and it would niether play or record. Removed the plate gently pushed all the ribbon cables and now it performs as new. Many thanks for the posting  |
Posted: Tue Nov 17, 2009 9:45 pm Post subject: Re: my Panasonic NV-DS65 doesnt playback and doesnt record : |
[quote="Sckorpion"]hello, so as i said Panasonic NV-DS65 camera would not play nor record!
i'm sure of the battery and the tape are perfect.
in VCR mode, I press play it plays the tape for about 5 seconds and then it stops automaticly and the Power light flashes many times then stops
the same problem in recoding.
please tell me what is the problem!
thx in advance[/quote] |
Posted: Sat Dec 12, 2009 11:03 pm Post subject: |
'have the same problem.
Don't know how to remove the screws....
I'll try
salut !!!! |
alexx_2010
Posted: Mon Dec 14, 2009 9:25 am Post subject: |
| I faced the same problem and it solved by restarting the camera and changed its software. |
Gambzo Guest
Posted: Sun Jan 24, 2010 11:04 am Post subject: Blinking power |
| Hi, I had same, blinking power and frozen cam. Agatha showed me the way... Just open the bottom, move and push the connections and by magic it's working! Thanks |
boricsson Guest
Posted: Wed Apr 14, 2010 9:04 pm Post subject: |
Hey here from Estonia!
Thank u very much for helping. Now my camera work normal. But there is some problem with little battarey wich is responsible for date\time cos i have to pull on this place where this battarey is to sweitch on VRC mode. |
sri Guest
Posted: Thu Sep 02, 2010 9:55 am Post subject: Same problem |
I too have the same issue , did you guys got any resolutions for this
pls help
sri |
sri Guest
Posted: Thu Sep 02, 2010 9:58 am Post subject: Re: Did you find a solution? |
did you figured out how to troubleshoot this problem
pl help
sri
| Michellesmith wrote: |
I have the same camera, and last night suddenly it would not work It has the same problem with the flashing power light and only working for a few seconds before making winding noises and switching off.
I know this forum is a bit old.... but did you get your camera to work???
Michelle |
kathleenp980
Posted: Wed Sep 15, 2010 7:57 am Post subject: Re: my NV-ds65 plays and records for 5 secs, then shuts off. |
[quote="[email protected]"]My Nv-ds 65 plays and record for 5 secs and then switches off. The power light then starts to flash and after about 1 minute the camera shuts down completely. I have checked all the menu settings and read the manual from cover to cover with no solution. Very anoid
The camera is only 2 years old.
Please help[/quote]
Thanks for the post. :roll: :wink:
__________________
[url=http://moviesonlineworld.com]Watch Jack Goes Boating Online Free[/url] |
teresap989
Posted: Mon Sep 20, 2010 7:22 am Post subject: |
This fault is the same I experienced a year or more ago with a DS65 - I had the camera repaired - cost me NZ$120 - and I was told the fault was a dry joint. I have now had exactly the same fault and thanks to this forum repaired it myself - well actually all I did was follow the instructions and push all the ribbon cables; nothing appeared loose, but I now have a functioning camera again. Thank you very much and long live Google
__________________
watch free movies online _________________ watch free movies online |
