jak Guest
Posted: Wed Dec 14, 2005 5:50 am Post subject: phillips matchline 29" TV |
Hi I justed started to get a squeezing of the picture to the right of the screen. The screen partially goes black and moves in towards the middle. It doesn't do this often and seems to flip back to the normal size picture but it seems to be getting worse. Any idea what the problem is please? is it going to die on me soon?
Thks |
Posted: Wed Dec 14, 2005 3:35 pm Post subject: Re: phillips matchline 29" TV |
[quote="jak"]Hi I justed started to get a squeezing of the picture to the right of the screen. The screen partially goes black and moves in towards the middle. It doesn't do this often and seems to flip back to the normal size picture but it seems to be getting worse. Any idea what the problem is please? is it going to die on me soon?
Thks[/quote]  |
Posted: Wed Dec 14, 2005 5:33 pm Post subject: |
sounds like you have a dry joint, try resoldering all the hv caps in the line output stage, these are prone to this problem, you need to do it before the line output transistor gets damaged. |
bobqwerty Guest
Posted: Wed Feb 15, 2006 1:47 pm Post subject: |
is that the only solution |
Posted: Wed Feb 15, 2006 5:26 pm Post subject: |
no, hv cap failure is also a possibility as is incorrect line drive but without knowing the exact model it is very difficult to suggest much else, dry joints are a very common fault on philips tvs, might be worth checking for djs on the scan coil connector on the coils themselves. |
Advance-CD Grundig • 203 Fisher • Acer Travelmate 230 280 Wistron Pelican • E4400-90621 MXG ESG Signal Generators Se • TV 1491AV 2091AV 1488M 2088M 2086MS 2089 • Opr. Guide Models CN-50, CN-144, CN-2200 • 932 a Philips • stv200n55f3 ST • Primare T23-DAB FM Tuner sm PRIMARE • Philips 3138 427 24420 [SCH] Magnavox •
