Posted: Fri Jan 21, 2005 6:27 pm Post subject: Rca Tv Picture dead-makes a shrill high pitched sound |
I have an rca tv approx 4 years old and whenever the tv is plugged in ,
it makes a high pitched noise and the power button has no function the screen is blank and the normal sound does not work |
md60
Joined: 20 Jan 2005 Posts: 2 Location: Southeastern Ohio
Posted: Sat Jan 22, 2005 8:22 pm Post subject: |
Squeal is caused by power supply being overloaded. Most common problem is shorted horizontal output transistor, usually Q4401. If transistor fails again after replacement, suspect bad flyback. If you give model / chassis #s I can probably get you replacement part #s. |
Posted: Wed Feb 22, 2006 1:44 am Post subject: Ive searched... |
Ive searched these forums and this is the closest I could find to my problem. my model # is f36649 and my chassis # is ctc203ca5. its an rca entertainment series. If this is the problem what would cause it? Thanks
Kev. |
zalds Guest
Posted: Thu Feb 23, 2006 9:56 am Post subject: |
yes the supply voltage is carrying a large current so its squeel check all the ckt for the suuply voltage [115 -135] what ever to all where thw b+ go through sample diode like r2m high voltage protector ,flyback,horizontal output,yoke,high voltage capacitor[mylars]error voltage ampfor the opto ....all the parts that the b+ is connected |
JS-203 PC Minolta • philips ba04a0f0102 fl11.10 psu sm Phili • 2sk3947 Toshiba • sch3 4 panasonic • gp160-01 CANON • fdg6301n f085 Fairchild Semiconductor • 105B=CM1200=CM1300 Philips • 2sd1127 Inchange Semiconductor • 5100 Finlux • 3500c RM-272 RM-273 SM l3l4 NOKIA •
