stevphens
Posted: Fri Apr 22, 2011 1:25 pm Post subject: Magnavox DVD player not powering up. |
| Have a 2-year old Magnavox DVD player/recorder that was working fine. Then one day would not turn on. So I bought another Magnavox VCR/DVD combo player/recorder machine. Within a year, same issue. Worked fine, then suddenly would not power up (not manually or with remote). I looked for fuses or reset buttons and found nothing, not even inside the case. Anyone know what the problem is with these machines? |
Posted: Fri Apr 22, 2011 10:12 pm Post subject: |
Planned obsolescence, Cheaply manufactured using the cheapest parts they can acquire so they can make largest profit possible, you know, "the usual reasons." _________________ You're over there, I'm over here. |
Posted: Sun Apr 24, 2011 2:09 am Post subject: Yep! |
Yep! I suspected as much...
Just hoped there was a way to bypass the off/on switch? |
Posted: Sun Apr 24, 2011 4:13 am Post subject: |
Put a jumper wire across switch.
Probably won't change anything. Most likely a power supply failure. _________________ You're over there, I'm over here. |
Posted: Mon Apr 25, 2011 1:22 am Post subject: thanks! |
| Thank you for the suggestion! I'll give it a try... |
