Posted: Sat Mar 11, 2006 2:04 pm Post subject: |
Put the red wire on the side that pin 1 is on the floppydrive.  |
Posted: Sat Mar 18, 2006 10:14 pm Post subject: |
as far as the turn on witn phone rings, that is an option in bios, called wake on ring or something simular. You can disable it in bios. changeing the modem most likely will not fix that. What that is used for is so you can be away from home and call your number and log into the computer with out being there. It is not a malfunction, just a setting.
Hope that helps |
idunno Guest
Posted: Tue Jun 13, 2006 2:13 am Post subject: |
Unfortunately there is NO EASY Fix for random resets.
I would suggest reinstalling your software from scratch with the bare neccessities just to prune that branch out of the possibilities. This is a good idea if you have had the machine for a while anyways.
After that start tearing into your hardware, the power supply and the memory are the two most likely suspects.
You can test the memory but it is not always reliable - especially if the problem is intermittant - Problems always behave when you test for them!!
Good Luck! |
maverick
Posted: Tue Jun 13, 2006 10:13 am Post subject: |
| Thanks to all who responded. I found out what was causing my pc to reboot. It was indeed the modem! For some reason the ES PI-56 Data Fax modem, from ESS Technologies, was causing the problem with my pc. I changed the modem and all went well after that. |
[email protected] Guest
Posted: Thu Sep 07, 2006 2:43 pm Post subject: |
| ague,reconfigures paperwork authenticate Koppers inundate,reticle,attitude: |
