Cucibuci Guest
Posted: Mon Sep 19, 2011 10:09 am Post subject: LCD Sharp LC-52XD1E |
When I push power on,there is only green led.Nothing's happen after that.Can someone locate me the problem? |
Posted: Mon Sep 19, 2011 5:59 pm Post subject: |
You will need to try a few more things before anyone is able to assist you.
Do you have sound? If so, take a strong light and shine it on the screen and look to see if you can see any indication of picture. This will indicate a back light issue.
If no sound, Sharp's normally will indicate the fault by having the power light flash. After initial power up, the power light may flash a combination of short and long flashes to give you an idea as to where the problem my lie. |
Posted: Wed Sep 21, 2011 12:13 pm Post subject: |
There's no sound.Only green led and without any flashes.I'm desperate.Can anyone help? |
train123
Posted: Tue Sep 27, 2011 4:05 pm Post subject: |
It's hard to say exactly where your problem is unless you have some electronics background or the schematics. Start by checking your power supply output. Since the set seems to turn on, your standby +5V should be okay but check anyways. You should also see +12 and +24. Depending on what you find out here will determine what to check next. |
Posted: Sun Oct 09, 2011 7:49 pm Post subject: |
More than likley the digital main board. It's not flashing a 1-1 which means panel, you have no sound, the green light is solid not indicating a fault, suspect the main. |
behringer xenyx 1622fx . Various • New Electronic Cold INDESIT • TX-25MD1P panasonic • MT 1060 Schemi e Distinta Comp.part5 DB • K7VT4A+ Asrock • DMREZ45 panasonic • MV025ABLK LG • SX-440 Pioneer • bcr35pn Infineon • OBXE-DA PR ug HP •
