tayninh55
Posted: Sat Sep 10, 2011 9:23 pm Post subject: Vizo Model VO420E 42" LCD |
Hi, I am trying to work on this TV. It has NO Sound, and NO light in or around the screen area (completely black screen). When the tv is plugged in,,,,,,,but off, the Vizo logo is yellow with black screen and no sound. When you turn the tv ON (with remote or button on side of tv) the Vizo logo turns white but you still have no sound and a black screen. This is the only response I get from the tv. I have been told that this is the symptom of a bad Inverter Board. On this model tv, the Inverter shares one board with the power supply,,,,called a Inverter/Power Supply combination, so when I replace the Inverter, I'll also be replacing the Power Supply too.
MY QUESTION; Some LCD's have an Inverter and also one or two Slave Inverter Boards?
Does anyone know if this tv has the additional Inverter Slave Boards,,,,,,,OR is the Inverter section that shares the single board with the power supply the only components involved in the Inverter Process? Thank You!!! |
Posted: Sat Sep 10, 2011 9:42 pm Post subject: |
Did you mean: vizio
Othr thn te buls n te panl.
Just curious. Are ALL 5-letter television brands subject to abbrieviation?
Sanyo = Sano
Sharp = Shap
etc. _________________ You're over there, I'm over here. |
Johnie Guest
Posted: Mon Oct 10, 2011 1:30 pm Post subject: |
Before you decide to replace the IP board (inverter + power supply), i suggest you to double check the output voltage from the PSU secondary side to trace out which voltage lines was cause the symptom. I had seen this model of service manual inside the LCD-Television-Repair.com as file name: VIZIO VO420E_LC420WUG (T42USVZB1RF-.VO420E1) LCD TV Service Manual. |
DEH-2016 SM Pioneer • TF Hua-Yu [radial thru-hole] CD288HL Ser • AVR-2800 MANUAL DENON • em2e a4 Philips • 5000094 B6700 ESPOL Jun72 burroughs • 36ZP38 ch[1].ZP38 TOSHIBA • RI-28CZ10RX LG (Goldstar?) • SY33-0069-3 3279 Color Display Terminal • Compaq Presario 3000 Series COMPAQ • 601A(Model601) Keithley •
