error H4 sharp 5316 AR-Digital Copier
Goto page 1, 2  Next
Maikle
PostPosted: Sat May 06, 2006 11:03 pm    Post subject: error H4 sharp 5316 AR-Digital Copier Reply with quote
Please can some1 kindly tell me how to cure a falshin error "H4" on the sharp AR5316??? I know its a sequence of buttons on the screen
Thank you
alpertevfik
PostPosted: Thu Jun 08, 2006 1:27 am    Post subject: Reply with quote
heater lamp&fuse ( broken heater)
RESET:clear -interrupt -0-interrupt
and 14 start-15 start
good luck
_________________
alp
View user's profile Send private message MSN Messenger
alexglobal
PostPosted: Sun Dec 24, 2006 2:36 pm    Post subject: About The Reset H4 error Reply with quote
good luck
I try the same seqence but failed for the H4 error, any advice is there pls.
send me. Thanks
Alex
Badereldin
PostPosted: Mon Jan 11, 2010 8:35 pm    Post subject: Re: About The Reset H4 error Reply with quote
good luck
send me. Thanks
Alex
Well plz try the simulation about 5 times if not. u have to check fusing unit. so disconnect the two cables, turn it off then disconnect the power reconnect the cables put the power then on. so u have to do the simulation respectively..
Badereldin
PostPosted: Mon Jan 11, 2010 8:40 pm    Post subject: Re: About The Reset H4 error Reply with quote
good luck
send me. Thanks
Alex
it is freely to contact me through [email protected] or +249 923611846
PostPosted: Mon Jan 11, 2010 9:26 pm    Post subject: Reply with quote
This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from http://www.justmanuals.com
[email protected]
_________________
Want To Fix Something?
http://www.manuals4you.com
PostPosted: Mon Feb 01, 2010 2:42 am    Post subject: Reply with quote
Try the simulation about 5 times if not. u have to check fusing unit. so disconnect the two cables, turn it off then disconnect the power reconnect the cables.
PostPosted: Sat Feb 27, 2010 7:56 am    Post subject: Reply with quote
H4 00 Content Heat roller low temperature detection
Detail When the fusing temperature is lower than
150C° after 55sec from the start of warming
up.
When the warming up complete temperature is
not reached in 30sec from reaching 150C°.
100C° after 20sec from ready start.
145C° when printing."
Cause Thermistor abnormality
Heater lamp abnormality
Thermostat abnormality
Control PWB abnormality
Check
and
remedy
Use SIM 5-02 to check the heater lamp blinking
operation.
When the lamp blinks normally.
Check the thermistor and its harness.
Check the thermistor input circuit on the control
PWB.
When the lamp does not light up.
Check for disconnection of the heater lamp and
the thermostat. Check the interlock switch.
Check the power PWB and the lamp control
circuit on the MCU PWB.
Use SIM 14 to clear the self diagnostic display.
sunday Isaac
PostPosted: Thu Oct 20, 2011 1:31 pm    Post subject: technical help Reply with quote
i'm Sunday Isaac i have sharp AR-5516S has code error H4 i dont understand why it has come pliz i needed your technical advice
PostPosted: Thu Oct 20, 2011 3:20 pm    Post subject: Reply with quote
This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from
[email protected]
_________________
Goto page 1, 2  Next
Page 1 of 2
SnimkiOt.com - Poblizo.com : ïúòåøåñòâèÿ
