Grover2000
Posted: Sun Jun 10, 2012 11:38 am Post subject: Philips home cinema HTS 3115 PSU fault |
Hi I have a Philips HTS 3115 Home Cinema with a PSU fault. When the plug is placed into the socket the internal fuse blows. I assume there is a short some where.
Does anyone have any knowledge this fault and what the suspect parts which may require replacement?
Any help on the matter is greatly appreciated
Grover |
Posted: Mon Jun 11, 2012 1:20 am Post subject: |
I am not familiar with the specific unit but blowing a fuse could be a number of things. It could be something in the power supply itself(like you mentioned) OR it could be a problem with an audio channel(final output) which is common in audio. Without further testing &/or isolation of the circuit, you can't predict? Are you technically inclined? Any test equipment? Do you know how to solder?
You can get a free service manual from elektrotanya.com |
Posted: Mon Jun 11, 2012 6:05 am Post subject: |
Hi and Thanks for your quick reply. I can try and locate a manual as for test equipment I have a multimeter and have no issues with soldering.
After checking the psu further I noticed that a component is burned and a dark patch is on the underneath the pcb in the same area.
Can I upload any images on this forum
Grover |
Posted: Tue Jun 12, 2012 12:37 am Post subject: |
You can upload an image as long as you log in with your registered name.
I use photobucket but you can pretty much use any other. |
