Sony TV Model KP-53XBR35 Power Supply problems
Bigaltoo
PostPosted: Tue Aug 10, 2004 5:58 pm    Post subject: Sony TV Model KP-53XBR35 Power Supply problems Reply with quote
Have been troubleshooting captioned for several hours. All DC voltages are either low or zero. Cannot locate short. Power transformer primary voltage is 62 AC which seems low.
Haven't serviced TV's in several years. Schematic states all voltages taken from ground unless noted to contrary. Primary and secondary seem to have separate grounds although symbols the same (????). Advice and suggestions please. Cordially, Alan
Neo
PostPosted: Sat Apr 15, 2006 1:16 pm    Post subject: What means THP651 Reply with quote
I`m working on the power supply of a TV Sony and in the diagram and Board it`s written THP651, it`s a little black box with three terminals and I don`t know what is it? Somebody know?
PostPosted: Sat Apr 15, 2006 4:47 pm    Post subject: Reply with quote
What do you mean by the power transformer?
The primary ground needs to be isolated from the secondary ground for safety reasons. Make sure you are measuring from the correct ground on a component. Most heatsinks are not at ground potential.
There should be nearly 320 Volts dc across the mains capacitor, if not check the bridge rectifier.
PostPosted: Tue Apr 18, 2006 4:24 pm    Post subject: Re: What means THP651 Reply with quote
it is probably the degauss thermistor which is used to remove any stray magnetic field variations round the crt, that is the loud buzzing noise you heere briefly at startup. cant be sure without knowing tv model no.
