Carlosraj7
Posted: Tue Feb 12, 2013 12:55 pm Post subject: Technics SU8044 |
Dear Friends,
I am a new member to this forum, please help me with this problem. A friend gave me a Technics SU8044 to repair. I noticed that both the power ICs (STK0039) have blown. I replaced both the ICs. Our mains voltage is 240 volts AC, I am using a Variac. I set the voltage at 100volts AC and switched "ON" the amplifier. The amp works perfectly well. Now as I turned up the AC voltage slowly, I noticed that at around 150 volts AC, the sound becomes intermittent. It comes on for a few seconds then goes off for a few seconds, and it keeps repeating this. As I turn the voltage even higher, the ON and OFF period gets even longer. When I set at 240 volts, the sound doesn't come on. If I reduce the voltage to 150 to 80 volts AC, It works fine. Can someone please give me a clue what can be wrong.
Thanks
Carlos Rajoo |
Posted: Tue Feb 12, 2013 11:38 pm Post subject: |
| Sure sounds like it is set to run at 120V AC? Are you sure it is set for 220~240? Does it happen to have a voltage selector in the back? what is the ratings on the label on the back of the unit? |
Carlosraj7
Posted: Wed Feb 13, 2013 11:21 am Post subject: Technics SU8044 |
| vtech wrote: |
It is set to operate at 240 volts AC, because that is the mains voltage in our country. _________________ JAGULU777 |
