youKnow
Joined: 23 Apr 2013 Posts: 3 Location: Houston, Texas
Posted: Tue Apr 23, 2013 7:37 pm Post subject: Sony MDR-V150 Left Headphone not working |
I have a pair of Sony MDR-V150 headphones and the left speaker no longer plays sound. For awhile, it would go silent, but I could fiddle with the housing and it would cut back in. Now it is just completely silent. The right headphone works properly. I took them apart thinking that a wire had came loose, but I found that the ground and the green were attached. I have no previous electronic repair experience, but I do have access to a soldering gun. I'm looking for repair tips. Thanks.
the headphones
right side (functioning)
left side (not-functioning, still connected)
left zoom
Posted: Wed Apr 24, 2013 2:36 pm Post subject: |
PLUG has three connections Ring - Center - Tip
RING should have continuity to the Braided shield on BOTH ear pieces.
TIP should have continuity to the center conductor of only one ear piece (left or right depends upon manufacturer).
CENTER should have continuity to the center conductor of the other ear piece.
Sounds like a broken center conductor of left wire at/near the housing. _________________ You're over there, I'm over here. |
youKnow
Posted: Thu Apr 25, 2013 1:03 pm Post subject: |
Thanks for your feedback.
| jts1957 wrote: |
Sounds like a broken center conductor of left wire at/near the housing. |
When you say housing, do you mean the headphone or the plug housing? |
Posted: Thu Apr 25, 2013 6:12 pm Post subject: |
| Quote: |
| For awhile, it would go silent, but I could fiddle with the housing and it would cut back in. |
You tell us. Is that near the plug or a ear piece? _________________ You're over there, I'm over here. |
Posted: Thu Apr 25, 2013 7:25 pm Post subject: |
| jts1957 wrote: |
| You tell us. Is that near the plug or a ear piece? |
The earpiece. Would you recommend detaching the green wire, cutting it and re-soldering? |
Posted: Fri Apr 26, 2013 1:07 pm Post subject: |
Presuming there is enough wire, I'd unsolder BOTH, cut back 1" to 2," restrip, twist, tin ends and resolder each to the SAME terminal as per original. _________________ You're over there, I'm over here. |
youKnow
Posted: Fri Apr 26, 2013 6:28 pm Post subject: |
| Well, I re-soldered the wires, but I'm guessing it doesn't matter because I popped the speaker, or coil as I understand it, out when I was initially messing with them. This disconnected, from what I can tell, two wires in the yellowish glue. I assume I would need to get two new wires, scrape off the glue and connect them, which I'm not going to attempt as I think I'll damage the circuit board attempting to remove the glue. Thanks for the help. Was an interesting experiment. I hate the idea of getting rid of some headphones when 90% of the components are still good. |
Posted: Sat Apr 27, 2013 2:41 am Post subject: |
As they say: live and learn. _________________ You're over there, I'm over here. |
