plimmy Guest
Posted: Mon Jun 03, 2013 2:02 pm Post subject: Denon AVR-1800 |
Hi all. I think I may need a replacement transformer for my AVR-1800.
The primary winding measures Meg ohms.
Two things really:
Does anyone have a service manual for this model?
And also does anyone know where I can get Denon parts?
Thank you |
Posted: Tue Jun 04, 2013 2:02 am Post subject: |
I do have a manual and I used to work with many Denon products several years ago. Not sure if that transformer is even available or how much?--used to deal direct with Denon for parts.
I can tell you that on many occasions, the problem with the open primary of the power transformer was actually a bad thermal breaker that is inside the transformer and 9 out of ten times you could follow the primary wiring and replace it with one on the outside of the transformer.
Provided that the windings were not overheated, it would be good to go. |
Posted: Tue Jun 04, 2013 12:21 pm Post subject: |
vtech wrote: |
Hi and thank you for the response. Do you have the manual in digital form?
Also how would I get to the winding as its wrapped?
Thanks |
viddoc
Joined: 29 Nov 2010 Posts: 1 Location: London Ontario
Posted: Wed Jun 26, 2013 3:06 pm Post subject: FIX TRANSFORMER |
MOST POWER TRANSFORMER HAVE INTERAL FUSE ON A DENON I JUST FIXED EMANALED COPPER WIRE ON BOTTOM OF WINDINGS ON PRIMARY SIDE WAS AFTER FUSE CHECK RESISTANCE VERY LOW 1-2 OHMS BE SURE TO AND FUSE |
philips service mode Philips • blf7g27l-100 blf7g27ls-100 Philips • sono-clock 550a Grundig • uifdu8dw NOKIA • Panel SAMSUNG LTI320WT-L07 0 [DS] . Vari • -1402-2002-2102 AIWA • 28SLD2E-E Panasonic • compaq ch8parts HP • USB3.0 Cable-Connector Assembly Complian • am8bmanual Wavetek •
