Whiterock Guest
Posted: Wed Aug 22, 2007 6:50 pm Post subject: TV Repairs |
My tv is on the fritz, 50ux58B Hitachi. Green diodes come on then off again in the interior of unit, red led blinking afterwards. Have not been able to locate C-707 nor E-994. Any good advise out there? |
FionaSmith
Posted: Tue Oct 27, 2020 6:14 am Post subject: thanks for your help related to T.v |
I have tested the coupon that saves 45 % on proflowers you can grab your coupon now |
miloking
Posted: Tue May 11, 2021 8:41 am Post subject: |
I have a Samsung TV model QN75Q7FAMFXZA, which has a blinking red light and won't turn on. When I press the power button on the remote, the remote just flashes red for a few seconds and goes away. The Tivo remote will not turn the TV on either, nor will the Apple TV remote. A couple of weeks ago, the TV would start to turn off by itself. This happened a few times but eventually it wouldn't turn back on. The TV is mounted on the wall and when I went to pull the TV out from the bottom to reach behind and unplug it, it suddenly came back on. This worked a couple of times but eventually the TV would not come on anymore. I figured the power cable must be loose so I removed the TV from the wall, set it on the floor and plugged it into a wall outlet but still the same results.
I have read forums and articles of which most point to a bad power board, usually due to a leaking capacitor. I have taken the unit apart and inspected the power board but to me, all the capacitors look fine. The board in the lower middle makes a clicking sound every 1 second or so. It's a very faint sound, not sure if that's normal.
Any suggestions _________________ Are You Looking For The Best Recliners? Here Are Some Of The Greatest Recliners that are affordable, luxurious, and above all - Comfortable! |
TS-1122FM sommerkamp • Process Flow Sony Ericsson • philips 32pfl5404 chassis tpm3.1e la Phi • bfp182 Siemens • C533 . Various • 2sc4754 Toshiba • YOKOGAWA 2041 Instruction Yokogawa • fqp45n15v2 fqpf45n15v2 Fairchild Semicon • hfe aiwa sa-p30 p30 st-r30 e k g parts l • sch13 panasonic •
