Farrell Guest
Posted: Fri Aug 26, 2005 3:27 pm Post subject: *** SONY BLINK CODES *** |
Does anyone know what the 10 blinks code means on power - standby LED for SONY TV model KV-HZ29 M65 ? Audio good but no video.
I've never fixed a TV before but I'm no stranger to fixing electronics. I wouldn't want to spend a lot of money into it. Any advice would be appreciated.
Thanks in advance. |
Posted: Fri Aug 26, 2005 6:22 pm Post subject: |
This is what I know.
# Continuous Blinking: Not getting reply from IC301 Jungle IC, Bad "IK" video path, possible short to ground
# One Blink: Not used
# Two Blinks: B+ over current protect, short in power supply or HV circuit
# Three Blinks: B+ over voltage protect: power supply short, check transistors, resistors etc.
# Four Blinks: No Vertical Deflection, Check IC1509, Q1505
# Five Blinks: AKB Circuit, Check Q705,Q732,Q761, on C board, also check Q218,Q219, Q220 on A board, IK circuit can also cause this try turning screen control up a little
# Six Blinks:No Horizontal, No Raster, checkC515 C516, & Jungle IC,IC206
# Seven Blinks: High Voltage Shutdown, Flyback, shutdown circuits/components
# Eight Blinks: Audio Circuit, IC406, PS401, PS402
# These Blink Codes are stored in the set and can be looked up to see what error codes have been stored, To pull up Diagnostic Screen push; Display, Channel, 5, Vol MINUS, then power, a screen should appear with the codes and number of times they have occured. Once the set has been repaired the ERROR CODES have to be removed by the tech, clearing is done by going into the service mode; display,channel,5,volume PLUS, power. Press 8 then Enter everything returns to the factory preset condition. |
Posted: Fri Aug 26, 2005 6:23 pm Post subject: |
| I've never herd of a 10 blink code. |
Newbie Guest
Posted: Tue Aug 30, 2005 10:10 am Post subject: |
| Error code more than 10 depend on your Sony TV model |
dpro369 Guest
Posted: Wed Aug 16, 2006 6:13 pm Post subject: 10 blinks |
| Mine has 10 blinking codes also -model KP-FX432-M91, anybody knows what is this? |
chylow Guest
Posted: Mon Oct 29, 2007 1:24 pm Post subject: My TV Problem |
Hi my tv it have code 10 Blinking too Audio is normal but No picture, I want to Know what the problems of it My TV Model:KP-FX432. How it can Repair?
Thank you |
Malik Guest
Posted: Sat Feb 07, 2009 10:44 pm Post subject: Re: 10 blinks |
| dpro369 wrote: |
HOW DID U FIX THE PROBLEM, MY TV , OS DOING SAME AND MODEL IS KP-FX432M91
PLS HELP |
Malik Guest
Posted: Sat Feb 07, 2009 10:47 pm Post subject: SONY TV BLINKS 10 TIME |
I HAVE SONY TV KP-FX432M91, ITS STBY LT BLINKS 10 TIMES, DOES NOT SWITCH ON.
WILL APPRECIATE IF SOME ONE CAN HELP TO FIX IT.
[email protected] |
Malik Guest
Posted: Sat Feb 07, 2009 10:52 pm Post subject: 10 BLINKS |
I HAVE REPLACED IC 8005 IN D BOARD BUT IT DID NOT HELP.
ANY BODY HAVE THE SERVICE MANUALS OR SCH. |
3S76 Tektronix • R7500 Grundig • 1988 29C3xx Series AMD • STR-DE915 Sony • FT101ZD_ yaesu • PD-F805 (RRV1601) Pioneer • 2sc5287 Inchange Semiconductor • Vizio VO37LHDTV10A MT5381P-SST(EU) AUOLC • LH-D6245D LG • tsm2302 a07 Taiwansemi •
