msu
Posted: Wed Sep 06, 2006 6:15 am Post subject: Philips FSQ Vision - Tuning and colour problem |
Hello,
For last two weeks or so my old Philips FSQ Vision has started forgetting tuning and colour settings. I have set a Sky box at channel 9. When I switch the TV off or put it on standby it forget its setting and every time I have to tune again and turn the colours on to make the picture coloured.
Any simple fix to this problem?
Regards |
Posted: Wed Sep 06, 2006 4:14 pm Post subject: |
| replace the internal memory backup battery, 1.2v or 2.4v depending on model. |
Posted: Thu Sep 07, 2006 6:06 am Post subject: |
| gary wrote: |
Thanks for your response. I will try this.
Regards |
msu
Posted: Mon Sep 18, 2006 6:10 pm Post subject: |
| gary wrote: |
Today I opened my TV. The only thing that appears very close to backup battery is a two sectional yellow round item (like capacitor but in paper casing rather than plastic), joint togather through a strip and placed horizonally just behind the main control knobs. They have flat strip connection to circuit board. It is showing only 0.023V (with TV off) and the only thing I can read is a + sign on one section and letters CLC.
Any idea what size of batteries they are (1.2 or 2.4V) and can I use any other backup batteries (say computer bios, or simple Ni-Cd rechargable batteries) of similar rating?
Thanks |
Posted: Tue Sep 19, 2006 4:20 pm Post subject: |
| that is the battery, if it is 2 sections in 1 tube it is a 2.4v nicad battery, dont replace it with a bios battery it may explode as the tv charges the battery when turned on, standard nicads would do the job perfectly as the originals are just 1/2 size nicads. |
msu
Posted: Wed Sep 20, 2006 6:36 am Post subject: |
| gary wrote: |
Thank you for your response gary.
The battery is in two section and in two small tubes (connected togather through a stip). As per your suggestion I will use a pair of rechargeable Ni-Cd batteries (1.2V each). I wonder if I should go for AAA or AA type?
Regards |
Posted: Wed Sep 20, 2006 4:04 pm Post subject: |
| doesn't matter as current required is very low. |
coiki Guest
Posted: Tue Feb 27, 2007 9:27 pm Post subject: Re: Philips FSQ Vision - Tuning and colour problem |
| msu wrote: |
Hello,
Regards |
hi! i just bought an old philips FSQ vision... and i was trying to set up my universal remote control but i just can't find the code!! do you know any code that might work?? |
Posted: Tue Feb 27, 2007 11:44 pm Post subject: Re: Philips FSQ Vision - Tuning and colour problem |
| coiki wrote: |
Are you trying to use sky/ ntl remote or any other after market universal remote? |
Posted: Wed Feb 28, 2007 5:01 pm Post subject: Re: Philips FSQ Vision - Tuning and colour problem |
| coiki wrote: |
yes! i live in spain i'm trying to use a sort-of-direcTV system, called Imagenio, wich uses a decoder called.. iCan3100TW by ADB, thanks!  |
