Nikuma
Posted: Wed Nov 08, 2006 10:02 am Post subject: AC Adapters |
Hi all
I'll try and make this make as much sense as possible...
I just bought a guitar pedal from the USA (i'm in Australia btw) and it was supplied with a US transformer with the following specs - INPUT: 120VAC 60Hz 5.5W / OUTPUT: 9VDC 300mA.
In my enthusiasm upon receiving the pedal I forgot to check the specs on the transformer and plugged it directly into a 240V mains power supply using a universal adapter (stupid, i know).
The pedal powered up for a moment and then a pop sound and a strong smell came from the transformer.
I assumed that the voltage from the mains power supply would have fried the transformer first and therefore cut the circuit to the pedal keeping it safe from a short circuit - does this sound right?
I went out and bought the following replacement transformer - INPUT: 240VAC 50Hz 8VA / OUTPUT: 9VDC 200mA thinking that the pedal would be ok and that this would do the trick.
I get home, plug it into the mains power supply & pedal and alas nothing happens.
Is it possible that I've fried the pedal circuitry? If so, is this sort of problem fixable? I also thought that the output of 300mA on the original transofrmer compared to the 200mA on the replacement might have something to do with it but I have no idea about this sort of thing.
Sorry for the longwinded explanation, any help would be greatly appreciated!
Cheers,
Nik |
dolescle
Posted: Wed Nov 08, 2006 11:18 am Post subject: |
Problems like this is very common with varying voltage sources.. I myself had done this silly thing, plugging directly to a 220V mains,I even call this The BIG POP, hehe..
Actually your right plugging your pedal directly to a supply twice its rated voltage will fry any circuitry.. Therefore your pedal is toast, but it's fixable, you can take it to your local repair shop and unfortunately pay the price for being innocent.. The BIG POP doesn't excuse anyone.. |
epi
Posted: Wed Nov 08, 2006 9:50 pm Post subject: |
Hi Nikuma,
Have you checked that the +/- connection of the new power supply mates the pedal input jack? |
fongs Guest
Posted: Thu Nov 09, 2006 7:01 am Post subject: |
| epi wrote: |
Hi Nikuma,
Yeap, like epi said, check the polarity of your DC supply.
IMO, yr pedal shd be still in working cond. if it has some sort of protection against incorrect DC polarity.
Also to add, your 200mA adaptor is abit under-rated compared to the original 300mA. Yr new adaptor will work but it may get hot as the pedal maybe drawing more current than the adaptor can supply.
Good luck! |
