geek101 Guest
Posted: Sat Feb 19, 2005 12:45 am Post subject: Sony TV Fault: |
Hi:
My 28inch Sony Trinitron ( Model: KV-29F2U), as this fault .......
When power-On, cant get any Picture or Sound.
Thanks  |
Melw Guest
Posted: Sat Feb 19, 2005 7:33 pm Post subject: Sony |
| A little more information would help. For example, do you hear a click when you press the power button? Is the standby light flashing and if so, how many times? You also might want to check out www.FreeFlatScreens.com/?r=10948674 for an opportunity to earn a free replacement for this set with a little effort on your part. |
geek101 Guest
Posted: Mon Feb 21, 2005 10:11 am Post subject: Sony TV Fault: |
Hi Melw:
First, when the TV is Powered-Up there is a click.
And second, the Standby Light flick once.
Thanks  |
melwats Guest
Posted: Mon Feb 21, 2005 8:26 pm Post subject: Sony |
| Since the TV clicks, it indicates that the standby power supply is OK. Unfortunately, one blink is not used for the self diagnosis on the Sony. My only suggestion would be that it is possibly the horizontal output transistor that is bad. |
THE GREAT OZ Guest
Posted: Sun Feb 27, 2005 3:09 pm Post subject: SONY TV TROUBLE |
HELLO, Well it's true that your standby supply is working, however you will most likely to have a bad power regulater in theses sets. The supporting caps around this device may also be somewhat dielectricaly absorbed and improper voltage may be on bias leg of regulator, Check the HV output trans like suggested this a common failure as well, Mostly a NTE-2353 will replace the device, It has internal damping so don't get a woody if the device does not measure correctly in circuit. OZ  |
manualst Philips • KVX2551D Sony • 2sc2412k sot-23-3l LGE • RL-40NZ60RB LG • OEM 715T2202 [SCH] . Various • esr70 datasheet en . Rare and Ancient Eq • b23nm60nd i23nm60nd f23nm60nd p23nm60 • DCR-SR87 SONY • 2sb1430 Inchange Semiconductor • CP-320 Daewoo •
