Ivan Guest
Posted: Wed Jan 03, 2007 2:50 pm Post subject: Transistors |
| Correction. Case should be correctly called the Collector and is usually connected to the case. |
JGrimaldi Guest
Posted: Sun Feb 04, 2007 8:17 pm Post subject: |
| As Ivan said, if there is DCV the anp will kill the output to protect your speakers, and bypassing the relay if this is the case will damage your speakers. What you can try is disconnecting the speakers, bypassing the relay, and taking a meter to the amp output and check it for DCV. |
gilloz
Joined: 03 Feb 2007 Posts: 33 Location: So. Cal High Desert
Posted: Mon Feb 05, 2007 4:07 am Post subject: |
| CLICK HERE to go to a website that will show you how to test transistors. You might have to hold down the CTRL key to bypass pop-up blockers. |
