Frank Guest
Posted: Sat Jan 20, 2007 9:27 pm Post subject: Pic Bleeding |
HI Guys, i have this RCA CTC197AH,CHASSIS F27680GY, is running goood exept a bit red bleeding, which i can take out just by reducing the color or adding more contrast,it's not tube because i used in it other chassis and no bleeding.Could it be
Red driver,red bufer,or one of the clamps or one of the resistors what you guys think.Thanks in advance. |
Posted: Sat Jan 20, 2007 9:35 pm Post subject: |
2SC3788 on the crt brd if you had no red but, Just go into the service menu and adjust red bias. |
Frank Guest
Posted: Sat Jan 20, 2007 11:27 pm Post subject: |
minnie wrote: |
Minnie you mean by reducing the red bias the bleeding will go away?Thanks, will try. |
Frank Guest
Posted: Sat Jan 20, 2007 11:31 pm Post subject: |
minnie wrote: |
Minnie you mean by reducing the red bias the bleeding will go away?Thanks, will try. By the way do you have Values for R14110,R14305,R14159, |
Frank Guest
Posted: Sun Jan 21, 2007 1:22 am Post subject: |
Minnie i turned down to red bias to -0 of caurse red bleeding has been reduced but not all, on some sceines or position of the pic still can see just a bit .because i like lots of color and don't use contrast at all, i read on a tip that the stand off resistor can cause this synthom what.s your thinking,thanks in advanse. |
Posted: Sun Jan 21, 2007 11:50 pm Post subject: |
Frank wrote: |
minnie wrote: |
R14110 20k, R14159 15k, |
Posted: Mon Jan 22, 2007 1:02 am Post subject: |
You could have a bad tube. Have you tried rejuvenating it? |
Frank Guest
Posted: Mon Jan 22, 2007 2:54 am Post subject: |
Minnie i don't have a juvenator. i turned down the red bias and the bleeding goes away, but it seems that after awhile of beeing on gets kind a vertical 4"band verticaly and pic fads away and i have to unplug it from the wall, and only turns back on after, i let it sit for some time, i suspect this type of set senses this change in the bias and turns off the high voltage,i say this because sound never goes a way i can here channel changing,What you think thanks.I also had this tip What you think?
this sympton is characterized by the presence of red, cyan, green, magenta, blue or yellow colour in a supposedly plain white raster. proper colour reproduction cannot be expected if the raster is coloured.
this symptom is caused by a poor white balance adjustment of by a trouble in the CRT, colour amplifier, color demodulation or colour output circuits.
if the raster has a tint of red or cyan, check the R-Y output circuits and the first grid, second grid and cathode circuits of the red electron gun. |
Posted: Mon Jan 22, 2007 5:28 am Post subject: |
White raster, move yolk back and forth, If correct purity can't be obtained leads me to a degausing problem or bad tube? |
dvp3100v eur si 313978531100.part2 Phili • Pioneer PDP-R04U PRO-R04U Pioneer • irfp140 International Rectifier • Lisa Sales Marketing Binder Feb84 apple • STV9470.1 Schneider • mra1000-14lrev6d Motorola • 2sc5839 Panasonic • FS-4020DN 2J0 3000.E08.001 Kyocera • 22sc4852 2 • B51-8585-20-TXT Kenwood •
