jorgeus12
Posted: Sat Feb 17, 2007 7:20 am Post subject: Failure to boot from hard drive |
I'll try to summarize the events leading up to my problem as best I can.
I have two hard drives. I tried installing Windows Vista Business on the first one to use in a dual-boot configuration with Windows XP which was on the second hard drive. Well, the Vista installation worked fine, but when I went to boot into XP, I found Vista's boot loader hadn't recognized Windows XP. Clearly frustrated, I tried several different things until I finally decided to format the first hard drive. It was horrible I lost my entire data from the Hard drive. Vista made my data vanish. I hate it. I tried using repair tool and many recovery software, but it did not work. Please help me out. |
gilloz
Joined: 03 Feb 2007 Posts: 33 Location: So. Cal High Desert
Posted: Sun Feb 18, 2007 5:13 pm Post subject: failure to boot |
CLICK HERE and see if this site can help you. |
pual45in
Posted: Mon Feb 19, 2007 5:38 am Post subject: Re:Failure to boot from hard drive |
I know Vista doesn’t install itself easily. Something must have happened, that’s for sure. What software you have used to recover your data? One of the data recovery software I know is Salvage Data recovery Software for windows. My friend used the software and got his data back. Few days back I tried to recover the data of my office system, which I lost accidentally while formatting and it worked well. Try with their software. I think their site name is salvage data.
All the best. |
robin_bga Guest
Posted: Tue Feb 20, 2007 2:19 am Post subject: Dual boot, Vista and Winxp |
I haven't tried installing Vista, but atleast i would tbink it this way. One is a new version and the other is not, so usually if u want to install and configure dual boot, u can either use partion magic or install the older version first then install the new version afterwords. Thats is the only way u can get vista to recognise Winxp.The only reason for this is, when ever u have a new release, they alway modify the MBR, its just like installing Linux, u can't install linux and then Winxp, obviously xp will control the MBR, but if u do vice verse, linux will recognise xp. About loosing yo data, i haven't tried SALVAGE before i have used GETDATABACK and i like it bcoz it uses RAW system, will go SECTOR by SECTOR / CLUSTER by CLUSTER. I find it more real, and it also filters the data to make sure u don't get junk files.
Wish u luck man
Robin |
GLP22M TX-32LED7FM TX-32LXD7M panasonic • Lenovo 3000 N100 and N200 IBM • 6210 quick repair layout NOKIA • [radial thru-hole] H7 Series Teapo • Focus ZX3 Ford • pcbhead panasonic • Схема DVD-1720 Ver. 2 DENON • pdtc143ee 2 Motorola • ixfh30n60p ixfv30n60p ixft30n60p Ixys • hcd-rv2 rv5 rv6 panasonic •
