Toshiba 53h71 turn off and back on
Yanmar
PostPosted: Thu Mar 01, 2007 5:27 pm    Post subject: Toshiba 53h71 turn off and back on Reply with quote
I fixed a 53h71 with a new stk 392-150. All works fine but now the tv turn off and on by itself. I found a service bulletin for the same problem but it's for a 50hx70 model... I must add a 47uF from QA01 pin 54 to gnd. Is it the same fix for a 53h71 ? Any idea ?
Thanks
Yanmar
PostPosted: Thu Mar 01, 2007 10:46 pm    Post subject: Reply with quote
Solder the jumpers on the signal board. IE the ones around L7711. Try that first.
Frank
PostPosted: Thu Mar 01, 2007 11:27 pm    Post subject: Reply with quote
Also Check Power Tact switch
cory
PostPosted: Fri Mar 02, 2007 1:09 pm    Post subject: Reply with quote
you should replace 2 convergence ic with original toshiba ics,otherwise you will run into strange problems.try that since other problem was not there before.
